2.5 liter 1997 Jeep Wrangler
So iv searched the web for sometime on this problem. First, it starts and idles fine every time. Engine can either be cold or hot. Happens in first gear at initial take off, or even at the point when the clutch is fully release and load is beginning to occur on the engine. Occasionally happens when shifting into second and load is beginning again. What happens is when I give it gas, easy or hard, the RPMs drop, one small pop out the exhaust (no pop in intake), and idles slightly lower than normal. I have to release the gas peddle in order for it to stop sputtering and than give the gas a tap to return to normal idle speed.
Things that have been replaced this week:
Idle air control sensor
MAP sensor
Intake Air Temperature sensor
Throttle Body Position sensor
Any Ideas?
MAP sensor
Any Ideas?
