My issue is that the BCM (Body Control Module) on my 97 zj was fried so when I got a new one and plugged it in, the jeep would start and die immediately because of a built in security measure. After some digging around I realized that I have to reprogram it some how and there are only a few options to fix my issue:
Option a. Get the BCM reprogrammed by a dealership or mechanic (I called 2 mechanics and they both dont know what to do with it) the dealerships all say that they dont have the tool they use to reprogram these old modules with (DRB scan tool I think he called it, or was it DRV? DRT?) or they just dont work on cars this old.
Option b. Get my own scan tool and reprogram it myself (Doubt it)
Option c. I've heard that if the VIN programmed in the BCM doesn't match the VIN programmed in the ECM the car won't start so if you take the BCM and ECM from a ZJ with all the same options mine has and plug them both in it should work. I seriously doubt this happening because I dont live near any junkyards, plus its an orivs and there arent that many out there.
Is there any other option I have that I don't know about? Is there a way I can just disable the security system myself?
any reply is appreciated
Thank you
Thank you
