1997 Grand Cherokee battery drain
47K views 22 replies 13 participants last post by  btotriad
Hi all,
First time poster. My daughters 1997 grand cherokee's battery has been draining and will only hold a charge for about 36-48 hours. We replaced the battery 6 months ago and just had it checked out and it is good.
It's been awhile since I've got into this sort of stuff but I whipped out my trusty multimeter and did some checking. I disconnected the postive cable, connected my multimeter to the post and cable and sure enough it was reading 188 milliamps of pull. I believe about 30 milliamps is normal for the clock, etc. I then proceeded to pull each fuse one at a time and when I pulled the 50A fuse, it dropped down to near 0.
According to my fuse box legend, this fuse (position 11 in the fuse box panel) is in line for the memory functions, power window, power door locks,power mirrors, remote keyless entry and the trailer tow package which we do not have.
My daughter told me that a few months ago the power door lock would not open the passenger side door which had to be opened by the internal latch of with the key from the outside. With this said, I definately see a connection between the battery drain (related to the power locks) and the door not opening when the power door lock switch is hit.
Any ideas on where to start would be much appreciated.
Thanks,
I am having the same problem on my 1998 Grand Cherokee
Hello teddysmith1952,
I just joined the forum yesterday and I am having the exact same problem. I posted a thread here as well. Maybe someone has gone thru this problem and has a resolution. I still haven't found an answer yet to fix it.
quarkdude
quarkdude
Hi quarkdude,
Interesting we have the same issues. Driving me nuts so let's keep our fingers crossed that "our hero" soon chimes in with the solution!
Jim
I have my fingers crossed as well, someone has to have had this problem as well.
I re-read your post and realized that I too have had door lock issues. My Jeep door locks would "buzz" or I call it "Stall" when the door lock button was pressed to unlock or lock. I fixed that by going to our local U-Pull-it place and getting a $10.00 electric door lock module and installing it. Seems like the door lock modules eventually quit working, just have to replace them. After I replaced the passenger rear door lock module, the Jeep seems to have a little bit longer now before it drains the battery. Not sure if those are related but worthy to note.
quarkdude
Thanks for that. Where exactly is the door lock module located?
I actually own a 1997 grand cherokee ( with 48 hour battery drain) as well as a 1998 (holds a charge fine). I just got back from doing some testing on both cars to see if there were differences in the volt and milliamp readings. They are almost identical so now I'm really puzzled and not convinced I have a drain.
I disconnected the negative cable on both jeeps. I put my multimeter, set to 20V and connected it to the negative detached cable end and the negative battery post. I hot a reading of 12.10 on both jeeps.
I then put the neg cable back on and removed the positive cable to do the milliamp test again. I put the multimeter probe (set on 200MA) on the positive battery post and the positive cable end and got a reading of 182MA on the "good jeep" and a reading of 190MA on the jeep with the problem. I then removed the 50A fuse on both jeeps and checked again. I got a reading of 12.11 on both jeeps. Again, yesterday after removing all of the fuses one at a time, the 50A fuse (for the power window, locks etc) was the only one that dropped the milliamp reading on the multimeter.
Almost identical readings on both jeeps!!! Crazy. Again the battery on the "bad" jeep was replaced 6 months ago and I took it back to walmart last week and they tested it and gave me the computer read out that it was as strong as new!
Hope this helps out in the troubleshooting department.
does the ZJ have a security system on them?
IF YOU CAN, try leaving the vehicle un armed on the system
when i removed my passenger door panel on my WJ, i left it off for a few days and the battery died.
also does the VIC display anything about the alarm or doors being open?
its a SWAG but hope it helps
Just for the heck of it, charge your battery, and then disconnect your negitive battery terminal for two or three days then reconnect it and see what you got .
I have a Caddy that was driving me crazy with a slow drain and I finally tried that and figured out that I had a bad battery cell.
It could be a bad diode in the alternator. If a diode in the alternator is bad, the battery will charge fine and hold a charge but for no more than a day or two. Try bringing it to your local Autozone or whatever and having the alternator tested. It's the easiest way to figure out if that's the problem.
Very good point Sir, I have some cool toys like a load tester and so such and I struggle at times to make it more simple here for y'all by assuming that you don't.
Please, don't ever believe guys that if Vato-zone tells you that your battery or alternator is good or bad that they are right.
Oops my bad ... Edit: add the starter too..
Hello wrenchenfool
You are the second person who has mentioned the d/s master lock module or power mirror module as the possible culprit to the mystery Grand Cherokee battery drain. I will set up my test light again and try pulling those connectors and see if the drain goes away. If it does I bet you have nailed the drain that I have been trying to figure out for a couple of years now. I will post results after I try it.
Thanks wrenchenfool, quarkdude :thumbsup:
188ma draw
I belive in my situation the heated pwr mirror is the drain I have one on order as soon as it arives i will inform you thank you
#18 ·
ill go with the alarm thing as well. i installed a python 1401 keyless entry and remote start and it killed the batt once.....but i would also recomend that you check on the stereo as well. if youve got the factory amp it may be pulling a draw on your battery as well if its not turning itself off. just my 2 cents.
#19 ·
Have a 98 Grand Cherokee and from day one have had battery drain issues. Pretty much found out that it is the factory security system that drains the battery. So setting the alarm or using the keyless remote even to open doors was a no no... Have read dozens of posts, other sites, etc. but have not found a foolproof way to disconnect the alarm without causing other issues... I am told it is intergrated with the ECM so I am just SOL... I don't use the keyless remote or set the alarm, but lock the doors manually and open them that way. This pretty much does the trick, but if it sits for a month or so I pull the battery cables off as it will still be drained by this alarm system... but it works good for days on end... hope this helps as work around...
#20 ·
battery drain 188ma
Hi the mirror was not the problem I was 99% sure it was but I was wrong good thing I was not charged for the mirror. like I had first posted when the mirror was pluged in to the d/s master door switch is when the draw would take place . As of now I still have the door panel apart and leaving work on friday I pluged the window switch in and the mirror when I got home I noticed the window switch was very hot when I went to unplug it so one of buides is going to get a hold of one to try. :confused:I have went threw the proper steps leading to the d/s door went thew all fuses all one at a time finding draw on 50amp fuse (for memory functions ) I have seen many post over the net on this problem but have not herd of any cures at work we have A site similar to this one were all techs post problems they have on different kinds of automobiles there was nothing for this same problem we all have so must keep diging deeper thanks :confused:
#21 · (Edited)
power drain
well guys same thing was happening to me so ... after a bit i narrowed it down to my front seats yes seats , heated with power lumbar ect i pulled overload J in the fuse box... gess what my draw in off cycle 208 went down to 013 no more battery drains !!!!! :cheers2: it was a faulty lumbar switch switch !! in the deflate poositin it was stuck..hense battery draw , the seat control no matter what pocket the keys are in are workable any time , good luck jeepstters nelson
#22 · (Edited)
I know this is a old post... But for anyone that happens to research this problem, I want to add my experiences with this.
I've had the same amp draw "problem.". It may not be a problem! Remove your negative battery cable. Hook up your meter between the battery post and the cable. Be sure your meter is set to the proper setting before doing this. Also, before connecting be sure everything in your Jeep is turned off. No lights, doors closed, etc. Attach the meter probes as directed above using zip ties to hold them to the cable and battery post. Positive to the cable, negative to the post. Then wait. My initial reading was around 190 milliamps as everyone has noticed on their jeeps. After several minutes, as the jeep control modules power down, you should get around 20 milliamp draw. Just give it time. I believe this behavior is normal. Hopefully, you'll notice the same pattern. If not, then you may have one of the problems others have posted here. I thought my first reading was a problem until I waited about 2 or 3 minutes.
#23 ·
I sure hope this helps someone. I to have a 97 Jeep Grand Cherokee and the battery will not hold a charge. After too many trips to my mechanic we finally found the culprit!! It was the rear defrost! It was draining the battery. ALSO…that fuse had been pulled so we don’t know how exactly the battery was able to pull juice from the battery.
