1979 cj7 304 v8 no spark solved. I pulled the jeep in the barn one day and the jeep kept running when I turned it off. Sometimes the starter kept turning over. I started it a time or 2 and same thing. I replaced the ignition switch. Now it would not start all. No spark.
It took me a few hours reading on the internet and in jeep manuals and several hours looking and testing on the jeep.
I had battery voltage at the + coil terminal and no spark at the coil.
I tried to follow the trouble shooting in the jeep manual and the internet.
I replaced the solenoid and still had no spark and still had battery voltage at the + coil terminal.
I tested the coil + to - terminals and got a good resistance value. I tested the coil + to the coil center contact and could not get a good resistance reading that was steady. So I replaced the coil and still had no spark and still had battery voltage at the + coil terminal. But the new coil had good resistance readings. The old coil was very old and rusty. I do not for sure it was really bad.
I then replaced the ignition module. I turned the key and it start right up, running great.
I just thought I would post and return the favor for what some you have given me here.
Thanks for the help.
