1-25-07 UPDATE: Since this article was written, Jeep caught on that the $70-$80 price tag for the swaybar was wrong. The new price is $1500-$1800! This is discussed from post 124 on. Also see this thread: http://www.jeepforum.com/forum/showthread.php?t=366356.
SUMMARY
The article will tell you how to hook up a JK swaybar with the electric disconnect system to your YJ. This will allow you to disconnect and connect your sway bar by simply flipping a switch! It is very easy and can be done in an afternoon if you work fast. The best part is that the entire project can be done for about $100. No that is not a misprint. A hundred bucks. You can hook it up in two different versions: (1) electrically, or (2) in a manual version that uses a knob (much like the RockLock which uses a Warn hub).
I know this works on YJs. I also believe that it will work on any Jeep on which the swaybar mounts to the bottom of the frame. I do not believe it will work on TJs because the sway bar is on top of the frame and bumper.
LET ME GIVE YOU THIS DISCLAIMER: Like many of you, I am not a mechanic or electrician. I am a simple hack/weekend warrior. Although the modifications I describe in this write up are working great for me, you need to be the final judge of how to do this modification. If you find any mistakes or things you would do differently, PLEASE POST THEM HERE! Once you install this on your Jeep make sure to cycle your suspension to make sure there are no clearance issues. YOU MAY NEED TO ADJUST THE PLACEMENT OF YOUR BRAKE LINES.
Also, do not power the disconnect motor on a full 12 volts of current. It will permanently damage or break the plunger assembly. As described below, you must wire in a resistor to limit the current to the motor.
INTRODUCTION
I was just plain tired of getting under the Jeep and disconnecting the sway bar every time I hit the trail. Then I had to go back under to reconnect when I was ready to go home. You have to be on level ground or it is a problem. You know what I mean; and if you have been in the mud it is especially fun. I have been with guys that took 10-30 minutes to do this because they were not on level ground. What a hassle.
So I decided that I wanted to hook up some sort of manual or electric swaybar disconnect system. I shopped around and all of the products like the RockLock (which uses a warn hub assembly) are only for TJs. I knew that the new 2007 Wrangler has an optional electrical swaybar that lets you disconnect with the flip of a switch. So I went into the dealership just to price what the assembly would cost and to see if it looked like it would fit on my YJ, although I had read that it was computer controlled. I figured if it was $350 or so maybe it would be worth it if I could get it to work on my YJ. But I was fully expecting it to be much more than that.
So the guy in the parts department at my local Jeep dealership looked up the part number on the computer, looks up, stares at me and says "That can't be right. It says the entire swaybar system is only $80."
I agreed that it must not include the entire assembly but he went ahead and ordered it (they are all back east) so that we could see exactly what it was that was only $80. Three days later the part comes in. It is in fact the entire JK swaybar with the entire disconnect assembly! Eighty bucks. I'm not kidding. I pulled out the cash and took it home.
Now....stop reading this article. RUN, don't walk...RUN to the nearest Jeep dealership and order yours before they realize that the computer MUST be wrong. The part number you want is 52060300AD. Eighty bucks delivers it. Below I am going to tell you how to hook it up in your YJ. Yes it works and yes it is the most fun, and "coolest" modification I have ever done to my Jeep.
HOW THE JK SWAY BAR WORKS
I am not an engineer, but in the process of figuring this modification out I did completely disassemble the JK electric sway bar. This is what I found:
The JK electric sway bar assembly is really simple. It connects and disconnects with the use of an electric motor. There is no need to detach the sway bar links, as we normally do with manual disconnects. There is an electric motor in the middle of the swaybar.
When turned on this motor pushes a plunger against a plate. When pushed by the plunger the plate moves in about 1 inch thereby disconnecting the swaybar. There is apparently a sleeve inside the assembly that moves along the sway bar on splines. Probably much like the Dana 30 vacuum disconnect system.
The plunger is driven by a screw which is turned by the electric motor. When the plunger reaches the limits of its travel the motor turns off and a "magnetic brake" engages to hold the plunger in place against the disconnect plate. The magnetic brake is what appears to be a coil with a magnet on top. The JK computer maintains current to this magnetic brake until the user wants to reconnect the swaybar, at which time the current is removed from the magnet. When this happens, the plunger, which is spring loaded, returns to the connected position and the swaybar reconnects. So the default/poweroff position on the sway bar is connected.
The width of the JK sway bar is basically the same as the stock YJ sway bar. It is designed to mount under the frame, just like on the YJ. TJs on the other hand mount over the frame so I do not think this modification will work on a TJ. But it should work on other models as long as the swaybar mounts under the frame. I will leave the ultimate answer of what other vehicles this will work on for someone else.
Using the stock YJ mounting brackets and mounting locations, the JK sway bar mounts right up to a YJ. The only differences are that the sway bar is about 1/4 inch thicker than the stock sway bar which means that you must machine out the stock bushings that are used on the mounting brackets or find an over the counter bushing that will work. Also the arms on the JK sway bar are about 3-4 inches longer than the YJ swaybar. This means that the links may need to attached to the top of the axle and not where the stock links go. However, on my Jeep, I was able to use the existing sway bar links as already installed. THIS IS AN IMPORTANT DIFFERENCE BECAUSE THE LONGER ARMS WILL PROBABLY HIT YOUR BRAKE LINES WHEN THE SUSPENSION COMPRESSES. AFTER YOU DO THE INSTALLATION YOU HAVE HAVE TO MAKE SURE THIS IS NOT A PROBLEM. AFTER INSTALLATION CYCLE YOUR SUSPENSION TO CHECK FOR BRAKE LINE CLEARANACE ISSUES. OTHERWISE YOU COULD BLOW YOUR BRAKE LINES!
The only other initial problem is that the JK swaybar is completely controlled by the JK's computer. So I had to find a way to work around that. It was also no problem.
Here is an important note: NEVER RUN THE MOTOR WITH A FULL 12 VOLTS OF CURRENT OR YOU WILL DAMAGE THE RETURN SPRING AND PLUNGER MECHANISM. The JK computer apparently limits how much current the electric motor receives to push the plunger to disconnect the sway bar. In trying to figure out how to eliminate the computer controls and limitations...basically in trying to figure out how to wire the electric motor directly...I operated the motor fully removed from the assembly on a full 12 volts of current. This basically caused the motor to overpower and break the return spring on the plunger as well as the "nut" that rides the plunger screw. (As discussed below, you must use a small resistor to lower the current to the disconnect motor). Therefore I was forced to buy a second sway bar. It was only $80 so I didn't really mind. This gave me a chance to fully open and take apart the first swaybar. In so doing I realized that there are two different ways you can use this system on your YJ.
The first, is to hook it up electrically. The second is to hook it up manually, without electricity. This ends up working just like the RockLock from Skyjacker, which uses a warn hub assembly. You turn a handle and the sway bar unlocks. Turn it the other way and it locks. Both are simple to install, but the manual version eliminates all the wiring issues.
Now...the introduction ends. Here is how you can do this modification to your YJ. I have tried to address all of the issues I faced. Hopefully if you follow my instruction you can do this very simply and have no problems arise. The first option is to go fully electric, and the second is a manual system.
SUMMARY
INTRODUCTION
