well, got a 90 s10 blazer, motor from a 93, 700r4, and 231c hd t/case....all in the donor, unfortunately!!:brickwall
i thaught the best way would be to get a complete, running vehicle, so i can see and drive the running motor,trans etc, and have all the wiring and accesories i need.... WRONG!!!!!
where do i start.......there is no way to pull the motor/tranny together, not enough room to raise the motor and clear the mounts and front cross member. not a big deal i hear you say......well...... the body has to be raised off the frame to get to 2 of the tranny/bellhousing bolts!!! basically undo the bolts, remove f/bumper and get jacking......the still have to use a u joint on the socket to get them out!!!
it took 2 of us to get the motor mounts undone, everything is sooooo tight in there, its unreal! cant get to the rear manifold bolts, so had to saw saw the exhaust, good ole rust....
removing the starter motor requires removing the front crossmember (which contains the ifs driveshafts etc)! screw that!
the tailshaft on the t/case hits the rear crossmember, so cant lower the tranny down enough to get the bolts/tranny out that way...and removing the tail end will still leave me the shaft inside it!:brickwall
so, i am currently a hater of chevy's......but i do like the motor/trannys, just wish they were an option in jeeps!:laugh:
all wires and hoses that i can get to are off and labeled, i already know the fuel lines are gonna be fun, not! everything else looks pretty straight forward, and i do love the remote oil filter!(although that tells you right there how tight it is..)
well, i have alcohol to drink, and will have the motor out tommorow even if i have to use my winch to pull the front end of it off!
will update when i get a chance.,.....later all!
