Jeep Enthusiast Forums banner
21 - 40 of 129 Posts
Discussion starter · #23 ·
VALVE BODY start by installing clip supplied in shift kit , if your not installing shift kit then watch for the steel ball that will fly away when you remove rooster comb
remove 3 screws holding pressure reg spring retainer on take not of where the short one comes out of
take note of which way the valves come out
now you can remove the E-clip from the rooster comb and remove it and the TV rod
remove pipe on left side of VB remove GOVENOR body remove solenoids
remove all screws holding VB together
remove OD accumulator and spring notice spring is broken
remove plate ** if your VB has this check ball take not it is smaller than the rest and it must be reinstalled **
not checkball locations the shift kit has a diagram of this so don't be too worried about it
remove screws from plate
note 2 checkballs we will only be rinstalling one (with or without shift kit)
TV valve train
here are the new shift kit parts and the new electrical
That's an excellent walkthrough, would it also apply to the 46RH?
Discussion starter · #25 ·
drill .050" hole thru casting at this point
using tool and 3/16 drill bit cut a groove in casting
this is what it should look like
drill seperator plate 3/16 here for HD use ** the kit does not recomend drilling here on JEEPS *** If it was mine and I was running big tires and more power I would drill if it was my daily driver probably not
drill 3/16 all models
drill 1/8 if hole is here if no hole dont drill one (I've never seen a plate without it)
if there are 2 holes here drill smaller one 1/8 if only one hole the kit will tell you to drill it out to a bigger size I think 3/16 or you can just leave it
drill .093" optional HD
clean and install just the one checkball shown
assemble plate with new filter and stiffener plate try to line up the hole best you can
remove 3 screws in this piece
replace purple spring with black from kit
Discussion starter · #27 · (Edited)
ok remove cover here and pull out plug and spring this may be different colors
remove E-clip
remove valve
replacement valve ** not needed or supplied if your VB does not have the black plastic GOV sensor **
lube and reinstall new valve
replace E-clip then spring and plug on the other side reinstall cover
remove cover we are going to upgrade to a stronger clip
new clip on the left notice it is thicker these love to break
all the checkballs back in place and guide pins installed
TV valve needs to be shortened ... if this valve is worn steel shortened replacements are available
shortened as per gauge supplied in kit
replacement green spring ** reuse orange spring if you want to keep your trans a smooth as possible **
start stacking pieces of VB ontop using guide pins to keep alignment *** DON'T forget the little checkball if equipt ****
Discussion starter · #28 ·
spacer plate
keep stacking
IF you have the black plastic filter this screw needs to go in this hole it is longer and has a washer under head (it's actually a filter screw )
connector pipe bend tabs to keep it in place
torque all screws to 40 in/lbs
4th accumulator new spring included in shift kit, install cover
new manual valve supplied in kit along with the groove we made allows this trans to fill the torque and lube the trans in park (which means we can now check the fluid level in park)
rooster comb install the steel ball and spring if it ejected when you took it apart ** make sure you hook it onto the manual valve ** I might have learned that from experience !!!
TV rod or lever pusher thing
new seal reinstall the washer and E-clip
make sure it is assembled like so
next I place VB in the vise with a rag like so
pressure reg valve the good ones are made of steel , the aluminum ones are the ones that make the anoying buzzing when in reverse, you can buy replacement steel valves from the dealer or you can buy a SONNAX one but if you use the sonnax valve DO NOT drill the .050 hole in the VB casting the sonnax valve has it built into the valve
converter charge ** make sure these valves are installed correctly they can go in upside down**
springs *note here is the stock PR spring on right * this would be considered standard duty
I have no idea what the **** your doing but good job!
  • Like
Reactions: Jmzzj5.2
Discussion starter · #30 ·
here is the PV spring retainer and the adjust for the main line pressure
this is the stock adjustment for the stock spring what you looking for is just shy of 5/16" gap here (considered standard duty)
shift kit spring
when using BLUE spring this is the adjustment for HD ** you can start winding up this adjustment to a max of 5/16" gap BUT it WILL be rude*** I don't even adjust it up when I build diesels that are chipped
couple pics of assembled retainer
ok take VB out of vise and start installing wiring harness this end likes to get damaged when you unplug it so it is good to replace it it comes assembled with new solenoids
screw down solenoid block
here is the GOV body you would find starting in about 1999.5 models with the black plastic sensor ** not interchangable with previous gold sensor**
install sensor if this was the early one you would flip it over and install the metal retainer clip
install GOVENOR into bracket
intall bracket and GOV onto body clipping the sensor into place like so
different style govenor solenoid (origional on left) this new one is said to be more resistant to contamination
there is a body and GM force motor aftermarket kit to replace all this assembly and is said to be the ANSWER to all GOVENOR problems BUT the kit is about $300 (rip off) and makes it costly to include in our units
install to VB and remeber to plug in wiring harness
installing park rod
wiggle jiggle twist output shaft
installed you will feel it POP past the park pawl
remember spring at accumulator
start the park rod into the rooster comb as you get the VB into place
remeber E-clip ** try not to drop this into trans that makes your day kinda crappy **
Discussion starter · #31 ·
push it into place it is alot easier if you lube the connector orings and shift shaft seal first
torque bolts to 100 in/lbs install filter this one has the deep pan with the deep filter
reusable pan gasket and remeber magnet in bottom of pan
if this bolt is too long the neutral safety switch will catch on it ... if the neutral safety switch is in place and you put too long of bolt here the pan will leak like a bastard and you will think it is the neutral safety switch leaking
****** DO NOT OVERTIGHTEN THIS FITTING IF YOU REMOVE OR REPLACE IT YOU WILL CRACK THE CASE YOU WILL CRACK THE CASE ***
sonnax makes a fix if you do crack it BUT just DON'T crack it ok
TA DA your done
i just rebuilt my 46RE at work also last week, not too hard, but for some reason i am getting a stream of fluid out in between the bell houing of the trans and engine, so i gotta take it back out. damn reman front pump...
nice write up though, this will help alot of people
Discussion starter · #34 ·
couple extra pics this is the older style govenor pressure sensor compared to the newer style not interchangable
Great post!
Thanks for taking the time to document the assembly.
Discussion starter · #37 ·
1994 - 1995​
Jeep Cherokee 42RE
Front Band:
72 in lbs. Back off 3 5/8 turns
Rear Band:
72 in lbs. Back off 4 turns
1996​
(Jeep and Dodge line)
42RE - 44RE
Front Band:
72 in lbs. back off 2 7/8
Rear Band:
72 in lbs. back off 2 turns
46RE - 47RE
Front Band:
72 in lbs. back off 2 7/8 turns
Rear Band:
1997​
42RE
Front Band:
72 in lbs. back off 3 5/8 turns
Rear Band:
44RE
Front Band:
72 in lbs. back off 2 ÂĽ turns
Rear Band:
72 in lbs. back off 4 turns
1998​
42RE
Front Band:
Rear Band:
44RE
Front Band:
Rear Band:
1997​
46RE
Front Band:
Rear Band:
47RE
Front Band:
72 in lbs. back off 1 7/8 turns
Rear Band:​
72 in lbs. back off 3 turns
Hey Baxy I posted this earlier in t he week and wondering if you have any ideas on this problem. Thanks.
1995 GCL 6 cyl. Trouble with auto Trans
Bought this used and ran great for a while and now it goes up to 3000 RPMs before shifting into second. Once there, the other gears shift OK. The kicker is, it doesnt happen all the time and yesterday on the parkway, she was running fine then downshifted on its own and I saw the OD light flicker on and off. Then that stopped and I got home with no trouble.
Had the transmission fluid changed today and the fluid and filter looked as good as new and the problem came back on my way home from the shop. I just came back from the store and it didnt happen once.
Discussion starter · #40 ·
hmmm I don/t know if I have ever had a complaint from a customer and then finding just the OD spring broken it really should just give a bit firmer shift because there is no spring to cushion the fluid rushing into the OD piston
