My Zj is leaking coolant from behind/above the crankshaft pulley, the leak itself is large enough to cause puddling in 15 minutes after shutdown. Ive done some searching and a couple threads seem to point towards waterpump going bad, and if the waterpump is bad that i should go ahead and do the thermostat as well. I would just like a couple more opinions from someone more knowledgeable than myself.
