WJ calipers need WJ knuckles and steering parts, and may need slight modifications to trackbar mount, hub-to-knukcle 1/4" spacer, some other small things. Look for "WJ knuckle swap", and you'll find polenty of info on this forum/ google.
WJ knuckle & brake swap including steering has been the single best mod onmy niner. There is a MAJOR difference in stopping power, and the WJ cross- over steering is also a big improvement over the ZJ/XJ/MJ/TJ inverted-y crap. Well worth the effort IMO. I spent total of about 700€ on my swap, including remanufactured calipers & brackets, knuckles glass-bead cleaned & powder coated, new rotors & pads, new Moog TREs + custom draglink + trackbar. I built the steering OTK and built custom trackbar mount and used JKS DIY trackbar in the front. Running UTK it's a bit easier.
I've got some pictures on my niner build thread.
