YJ speedometer not working
36K views 23 replies 16 participants last post by  Inspector Ratchet
I have a 1995 yj with a 4.0 5 speed. The tack wasn't working but the speedo was working,so I replaced the speedo cluster and replace the speed sensor in the transfer case. I Have power at the plug on the transfer case,the two outer wire at the plug, the center has no power. I have use a drill to ck to see if the Speedo is working and it's not. Also ck the gear in the transfer case and it seems to be working ok???? Any thoughts? Thanks Joey
When you used the drill did you have it in reverse?
Are you sure your speedo gear in the t-case is clocked correctly?
