Hello all. I just bought a 2001 jeep grand cherokee limited with the 4.7. The motor has a knock but i didnt think it sounded like a rod knock. idk.
Here's what i done so far..
compression test. all cylinder are 135 psi.
took off flex plate access cover to inspect the flex plate and bolts.. all looked good.
I did notice 2 bolts are loose on the driver exhaust manifold but didnt think that would cause the engine knock..
What do you all think is causing the knocking ?
