Alright, I've been having issues lately with my fuel system. If the jeep sits for a while, a week or so, without running there is no fuel in the lines at all, which when cranking takes forever, practically killing the battery to maybe get fuel to the carb. I've replaced the fuel pump recently (double-checked it by moving the lever while holding my finger over each end for suction/pressure), and I've checked the fuel filter was clear. Was able to suck fuel from the tank to the pump, blow air into the carb, and blow air into the tank via return line. So I've confirmed no clogs or larger cracks. All my connections have clamps some have extra clamps. I've recently moved the fuel filter up high to the grill brace, it was located about 8in lower on the fender well, but this did not change anything. I've also scanned both metal fuel lines back to the tank for stains or visible damage.
So here is my thought, it would be nice to have the fuel pump turn on before cranking the engine so that the carb bowl was filled and ready to go. Need to have a safety shut-off in case of an accident, so I would need to wire into the oil pressure switch. If I use a relay to power the fuel pump, how would I wire in the two switches? Can I just connect the two, or would that end up causing back feed and constant power to the "S" terminal when running?
Relay wires
Relay wires
- 30 power
- 85 ground
- 87 to pump
- 86 to "S" terminal and oil pressure switch?
