All,
Searched and what I am seeing seems unsafe for jackstands. Says to put them on the frame, but I would be surprised to find a jackstand wide enough for the frame. Frame is 4" wide, jackstands are 3.5"
Any thoughts or pictures would be helpful.
Below is what I am finding.
https://www.cherokeeforum.com/how-tos/a/jeep-grand-cherokee-1999-2004-how-to-jack-up-your-car-397785
Here is what the service manual says.
LIFT POINTS
STANDARD PROCEDURE - HOISTING AND
JACKING RECOMMENDATIONS
FLOOR JACK
When properly positioned, a floor jack can be used
to lift a WJ vehicle (Fig. 7). Support the vehicle in
the raised position with jack stands at the front and
rear ends of the frame rails.
CAUTION: Do not attempt to lift a vehicle with a
floor jack positioned under:
² An axle tube.
² Aluminum differential.
² A body side sill.
² A steering linkage component.
² A drive shaft.
² The engine or transmission oil pan.
² The fuel tank.
² A front suspension arm.
HOIST
A vehicle can be lifted with:
² A single-post, frame-contact hoist.
² A twin-post, chassis hoist.
² A ramp-type, drive-on hoist.
NOTE: When a frame-contact type hoist is used,
verify that the lifting pads are positioned properly
(Fig. 7).
WARNING: THE HOISTING AND JACK LIFTING
POINTS PROVIDED ARE FOR A COMPLETE VEHICLE.
WHEN A CHASSIS OR DRIVETRAIN COMPONENT
IS REMOVED FROM A VEHICLE, THE
CENTER OF GRAVITY IS ALTERED MAKING SOME
HOISTING CONDITIONS UNSTABLE. PROPERLY
SUPPORT OR SECURE VEHICLE TO HOISTING
DEVICE WHEN THESE CONDITIONS EXIST.
LIFT POINTS
FLOOR JACK
² An axle tube.
² A body side sill.
² A drive shaft.
² The fuel tank.
HOIST
(Fig. 7).
