I'm in the process of modifying a Wagoneer axle to install in a CJ-7. Some lessons I have learned. Follow along and I will attempt to relate the trials and tribulations I encounter.
1). I bought the front and rear axles out of a 1979 Wagoneer because they were Dana 44's. That would have allowed me to use 6 lug wheels front and rear.
2) Problem #1 rear axle is offset to accommodate gas tank. Scratch using rear axle. I though about cutting it but didn't see anything about it on the internet so I opted out.
3) Searched the web and found out an Isuzu Rodeo or Honda Passport has a Dana 44 and disc brakes on later years. Found one bought it. It has 4:10 gears great I like that. 19993 Isuzu has factory installed disc brakes and emergency brake drum. Got brake lines and all so it should just need to move spring perches and get adapters for lines.
4. I found out that I got a wide track front end. The WMS is 65.5 inches. It is the same front end Jeep used in a J-10. So now I have to make a decision. Some on the forum just outboard their springs but that is generally done with a standard width front which is 62.5 inches WMS. I didn't want to do that so I was going to cut the front on the long side the 3.5 inches and re-weld the knuckle. Now I am going to have to figure out how much to cut. Some information alludes to cutting both sides. I don't want to do that so I am just going to cut the long side.
5. I had 3:54 gears in the front and in order to match the rear 4:10 I am going to have to re-gear. Problem #2 I'm thrifty (or cheap depending on which mood my wife is in). I didn't want to buy gears and a new carrier as the carrier break is 3:73. Back to the web. Found out you can use the same carrier but you need "thick" gears. I hope that is correct.
6. Found what I thought was a deal on a Spartan Locker on Amazon for $255.00 plus $4.00 for shipping. That was at least $50-$140 cheaper than anywhere else.
7. Currently waiting on parts. I got gears for a Rodeo which are thick and match the rear ratio. I cut the spring perch off the long side and developed a new respect for welders at the Jeep plant. I'm going to remove the shock mount and then attack the Knuckle. Meanwhile I plan on wearing out three tape measures confirming measurements before cut anything.
