VIDEO - help - 4.0 loose rocker arm cause a tick/knock?
6.6K views 6 replies 5 participants last post by  Krazymaan
Hi everyone,
Long time reader, first time poster. I have had a few XJs and TJs over the years. I love working on them.
My 2002 Jeep TJ has a tick/knock that has gotten a little worse after a recent 2 hour drive on the freeway. I did a compression test and all cylinders are fine. I did a 10 minute engine "flush" and oil/filter change 5w30 but the noise is still there. The "flushed" oil did not look black. Also to note- the jeep had a cylinder 1 misfire a few months ago but a new coil and plugs fixed that.
My trusted mechanic listened to the motor noise with a stethoscope and thought the noise was coming from the top end / valve train. Also to note- the noise does not go away after the motor warms up. The tick/knock increases with rpm and occasionally seems to go way if I am cruising at a contestant rpm around 30 mph.
He suggested that I open the valve cover and inspect, so that's what I did. I found two loose rocker arms that move side to side about 1 cm. See video below.
Could this movement in the rocker arms cause a very loud tick / knocking noise (as show in the second video)?
Video: loose rocker arm
The tick sounds like this, see video below at the 30 second mark:
Thank you for your help!
Keep Jeep'n!
Kevin B.
To put it simply.....no.
If you were to check each pair of rockers with its respective cylinder at TDC, they would have a side-to-side motion as you showed in the beginning of your video.
Your problem lies within :(
And you guys are sure it's top end noise? I have had the torque converter bolts come loose and hit inside the bell housing. Sounded like an engine issue but once I took the inspection cover off and saw the bolt heads had wear marks on them, I tightened all the bolts and the noise went away
my go to for lifter tick is 'RISOLONE' just add to oil leave till next change. your call @10$ .
Jeep lifters/pushrods are non adjustable - makes simple lash adjustment a PIA.
I can't ck out videos well not easily but will later -
Can you add history - how long have you owned jeep, just started ticking? Any previous eng work?
Oil and filter - you use X weight and Xfilter and change ?
Migh want to remove push rod and inspect ball seat at lifter, that will also set up a retorqueing.
I would do the old move a rocker arm to another location test. Could have a slightly worn rocker arm shaft, or a worn rocker arm. put the "bad" one up to the front and see if he sound moves with the rocker arm move. Then you probably have a bad lifter or a slightly bent or compressed push rod. Oh yeah. Back in in the day when Eric wasn't sporting a scraggly gray beard and hippie hair.
