Afternoon, I've been banging my head against the wall troubleshooting this problem. Hours of research and I cant seem to find another forum or posting about this identical issue.
So I have a 05 wk 4.7 limited. This started about a year ago but a friend wants to buy the jeep so I'm running through fixing as much little stuff that's wrong as possible (door handles, SRS codes, fluid changes, as so) but this issue seems to be a stubborn one
So driving around and the airbag light comes on, and my HVAC shuts off. Airbag light goes away and HVAC comes back. Code B212D. Run relay. I've been through the tech authority steps just hitting dead ends. I've changed the ignition switch and ORC. With not much change. When the light comes on I'm also noticing the auto headlight brights message comes up(Auto bright headlights off) like I turned it off myself. But I did not. I've also went through and did dielectric grease on anything in the circuit. and the connections under the seats and the 2 connections in the left driver kick panel. (Connectors with 10mm bolts securing them) Any steps would be greatly appreciated. Thanks.
