1 - 4 of 4 Posts
92XJCowboy
Discussion starter · #1 ·
Does anyone remember something about bolting a block of zinc to the frame of your vehicle to help prevent rust? Or something like that? :confused::confused::confused:
I think the logic is that the zinc would act as a sacrificial metal and deteriorate over time instead of your steel bodied jeep or ford.
Or am I just crazy and wishing for to much.
Yes, they use this in large steel ocean vessels. Also, you can purchase zinc strips that are intended to prevent steel roofs from rusting. Yes it works but it works on the process of electrolysis which means you need an electrical connection between the zinc and the steel that will be protected.
Being a gearhead living on a low budget in the ever worsening rust belt has given me a unique hatred for rust.
Something I've found to work very effectively is Zinc Rich or Cold Galvanizing primer. I use it now on all my fabrications and it helps A LOT. You can buy it from rustoleum in two grades, expensive one is compatible to all types of paint, cheap one requires a latex topcoat because it is incredibly porous. I've seen on one or two occasions that it's available by the quart or gallon from hardware stores for use on barn roofs. I've never used this brush on stuff.
I've been using the more expensive grade of rattle can rustoleum for about 4 years and I've been very pleased. Note, once again, best practice is for the zinc to be directly against the metal.
Discussion starter · #4 ·
okay I will look into that paint when I get my new truck (new to me).
Thanks
1 - 4 of 4 Posts
