I'm beginning to think that a leaky Jeep is just a fact of life. The transmission cooler line on my '95 GC has had a leaky fitting at the radiator for almost as long as I've owned the vehicle. I seem to have leaks on both lines. I've read other people complain of this, and not wanting to spend $100+ from a dealer to replace everything from the radiator to the transmission. I agree. It sounds like the lower radiator fitting has a plastic clip that allows the hard line to mate to the rubber hose and in my case, this thing is what's leaking. The short section of rubber hose then has a screw fitting that connects near the front of the oil pan. If possible, I would like to replace that short section of hose, all the way up to the radiator itself, but I don't know what size fittings I need to look for. The upper line, has the steel hard line connected to the radiator housing and comes down past the lower junction and attaches with the same kind of plastic clip. That's my second leak. The other end of that rubber hose, does not have a screw fitting, but instead uses a crimp fitting to attach it back to hard line, making it more of a hassle to fix. But if I had to, I suppose I could cut the rubber hose a few inches past the plastic clip fitting and make a similar compression fitting.
