OK,....I'm dealing with a number of issues on my 1974 CJ5 project. One minor question that I am presently trying to sort out has to do with the oil for the transmission and the transfer case. As best as I can tell the transmission is a T-14, manual 3 speed and the transfer case is a Dana 20. My question is do each of those have their own oil or do they share the same oil. I've drained and then replaced the oil for the transmission (I used 85w-90 gear oil). If the same needs to be done with the transfer case, I don't know where the check/fill plug is or where the drain is. A small additional complication is a PTO added to the transfer case. The jeep had a PTO powered front wench when I first acquired it but I have taken the wench and PTO shaft off and will not be using those. I assume that the PTO has its own oil but I'm not sure about that either. Lots of questions and would appreciate any helpful info......Thanks
