So I’ve been doing a ton of reading and just want to make sure I’m right before I tackle this job. Need some reassurance and a little guidance.
Working on my 1987 YJ. Getting ready to pull engine. First of all, how many bolts hold the bell housing to the block? I see 4 in the back side (14mm?) and two larger ones on the lower backside. (Don’t know size). Then what seems to be a couple on the block side of bell housing.
So is there only 4 bolts holding bell housing to block?
And in order to remove top 2 bolts, support tail section of TC with jack. Remove cross member and tranny support bolts. Lower tail end of tranny and should have enough room to remove bolts. Motor mounts still attached?
I’m surprised there isn’t a video of this anywhere as much as I’ve read about it! I think PO did away with torx bolts, so that shouldn’t be an issue.
