can someone please tell me what the tip start is? thanks
Yes. Tip start (automatic transmission) will engage the start motor until the engine starts or for 10 seconds, whichever is shorter.In the automatic, you only need to turn the key to "start" for an instant, and the computer will continue to crank the engine until it has started for you. Most new cars (CANbus cars) will do this, since the ignition is no longer wired to the starter relay. Its just a switch wired to the computer.
In the manuals, you must turn and hold the key until it starts.
No tip start on the manual. Though it might have a restart disable feature.i'm pretty sure my manual does that too. I noticed it when I moved from a '93 Impreza with a chipped flywheel to the JK. HUGE DIFFERENCE!
Really? My 96 ZJ has no tip start and it does have remote start...? Not factory like my wk but this tip start is something I would never have stumbled upon. I bought mine used and wasn't sure what it was. I thought maybe it was like the newer cars with the push button and maybe it was finger "tip" start. Now I am clear though, another great reason for being a member of JEEPFORUM.TIP START is what makes it possible for the automatics to have the "remote start" as an option!
I'm not sure what you are saying.Tip start is not REQUIRED for remote start. However with remote how do you know if you are staying on the button too long and dragging the starter, or your 5 second push was not enough to fire it?
Tip Start makes remote EFFICIENT by cranking until running or ten seconds whichever is shorter (as stated above) with one touch of the button (or key).
The other main thing tip start does is simply reduce voltage demand. When the switch sees 12 volts and sends it to the solenoid you can have the solenoid fire as low as 10 volts! However when you use a RELAY to fire the solenoid and the switch uses 12 volts this drop out can occur at 11 volts (not enough juice for both relay and solenoid). By using the canbus to tell the computer to fire the solenoid the relay is triggered at a lower voltage (I think i read somewhere the canbus voltage is 5.5). This all equates to an increased ability to start at a lower voltages after an unplanned drain of the battery.
maybe I am not sure what I am saying either! lolI'm not sure what you are saying.
It looks to me like 12 volts goes through the ignition switch. The computer sends 12 volts to the starter relay, which sends power to the starter solenoid coil.
I don't see any place of reduced voltage demand in the JK starting circuit.
