Greetings from the newest member on the forum.
Does anybody know where to source OEM/Chrysler documents or shop manuals that address troubleshooting errant ignition timing issues that produce grossly advanced timing (22+/- degrees at idle on an induction style timing light) and the resultant severe detonation above 2000+/- RPM) under moderate load (highway speeds in 4th gear on the upslope)? Other than this the vehicle starts, runs, and operates without complaint like it was new. No 'dieseling' when turned off. Normal temp, oil pressure. No obstructions in intake system and air cleaner filter is serviceable. Produces plenty of power. Fresh 92 octane fuel. No recent engine compartment repairs or "fiddling with things." 132K.
I have relevant Chrysler specifications that state the timing cannot manually be adjusted, which means something is telling the ECM to ignore the 9.5% BTDC specified at idle and run riot instead. Question becomes "which sensor(s) to test and what testing to perform?" Without the necessary docs by Chrysler, I'm in the dark. Any leads or referrals would be appreciated.
Thank you in advance for your assistance.
