Hey there, I am prepping for my Speedhut gauge install and I have a few questions / things I want to confirm before I start hacking into my wiring harness. This is for the 3 gauge kit with integrate tach and it is going into an 81 CJ7. I'm not an electrician so have a lot of questions. Hopefully someone can answer all of them and this post can be helpful to others too. Here they are:
1 - Parking Brake Light - There is a black wire (#7) on the Speedhut gauge. The stock gauge has a black wire and a red wire.
- I believe I connect black to black, correct?
- If so, what do I do with the red wire?
2 - Fuel Level Gauge - There is a White wire (#10/Signal) and a Black wire (#9/Ground) on the Speedhut harness. The stock gauge has a pink and a red wire.
- I believe I connect the white wire to the pink wire, correct?
- Can the black ground go to any ground such as the black ground wire from the stock Tach?
- If all that is correct, what do I do with the red wire?
3 - 4x4 Indicator - There is an Orange wire (#11) on the Speedhut gauge. The stock gauge has an Orange wire and Red wire.
- I believe I connect orange to orange, correct?
4 - GPS Hot Start - There is a Red/Black wire on the Speedhut gauge that is supposed to go to 12v constant (non-switched).
- I was going to us an Add-A-Circuit on the Fuse Box for this. Is that ok?
- What fuse location & fuse size would be good to tap & add to?
5 - Temp Gauge - The kit comes with a replacement temp sender w/ a wiring harness that connects to the Speedhut gauge. The stock gauge has a Purple w/ Tracer Wire.
- Do I just install the new sender, connect the harnesses, and cap off that Purple w/ Tracer Wire?
6 - Tach Gauge - There is a Yellow wire (#17) on the Speedhut gauge. The stock gauge has a Red Wire and a Red w/ Tracer Wire. It also has an Orange Wire and Black Wire.
- The Red Wire and a Red w/ Tracer Wire I believe are the signal wires, is that correct?
• If so, how do the stock Red Wire and a Red w/ Tracer Wire connect to the Speedhut yellow wire?
- The Orange Wire and Black Wire I believe are the ground and power for that gauges illumination, is that correct?
• If so can I use the stock Black Wire as my main chassis ground all connections (i.e. - hook it to fuel sender ground, power distro ground, inverter gauge lighting ground)?
• If so, can I use the stock Orange Wire as my main 12v dash lighting source for all connections (i.e. - hook it to power distro dash lighting 12v & inverter gauge lighting 12v)?
7 - Power Distro Cable - Can you confirm these connections are correct / appropriate:
- 12v Keyed Ignition (#14 Red) - Ok to connect to the Red wire from the stock fuel gauge?
- Ground (#15 Black) - Ok to connect to the Black wire from the stock tach gauge?
- 12v Dash Lighting (#13 White) - Ok to connect to the Orange wire from the stock tach gauge?
8 - Speed Signal Wire (#2) - This wire on the Speedhut gauge I believe is for an Optional backup speedometer sender connection. What do I do with it?
9 - OBDII Snap Connection - I assume the jeep doesn’t have an OBDII connection and this just stays unused, correct?
