With the rear, you will need to weld new spring perches on the top or you can buy a kit that keys into the factory perch on the bottom (I think Motion sells it?). For the price of that kit, you could take the Jeep to a shop and they would do the SOA for you with welding the new leaf perches on top, and basically everything else (assuming you provide the parts). With the spring plates swapped, you can run your stock shocks in the rear. The only issue with that is you're limited to the flex. If you're looking for more flex down the road, you can lower the shock mounts to tabs welded onto the axle. If you don't care about flex too much then you should be fine (I can fully flex the front till it hits the fenders and not have any issues with the shocks in back). With Comanche's, since the drive shaft is so long in back, you can easily do a SOA and still use the stock drive shaft with no transfer case drops or need to swap to an SYE. When I did just the SOA on my Jeep with the stock drive train, the drive shaft came out maybe 3/4" from the transfer case, which still gave plenty of threads to "slip" on without worrying about it coming out.
A front lift consists of control arms, shocks, coil springs, longer brake lines, and a track bar. You can change the steering linkage if you'd like but I still run a stock steering setup on an 8.5" lift with no issues. A 5.5" and 7.5" lift in the front requires pretty much the same amount of parts, just the parts are a little longer to gain that extra 2" of lift. After the lift, you will need to get the Jeep aligned.
