I apologize for jumping on an old thread, but I don't see much new on these and I've been researching options to outfit my newer jeep. I'd like to share some ideas with anybody else making a similar search. Here's a couple of thoughts about what I've read on this thread and others like it. I'm not necessarily right, but I've used and broken at least a dozen of these over the last 30 years so I have some experience to back up my opinions. I have pulled my full size rigs out of all kinds of stuff with an 8K come-along, ~100ft of cables, chains, straps, etc. and a lot of sweat. I've even flipped over my F150 that was on it's lid 20 feet over the road bank, drug it back onto the road, duct taped my mirror back on and kept wheeling all afternoon. It took hours, but it works. A winch would not have helped me flip my rig, or pulled it backwards up the bank.
I wouldn't recommend skipping the electric winch if you're the safari type that says that never turns back, or goes down hills they can't get back up. Personally, I'm willing to turn around when I come to something my rig isn't capable of. I'm always looking for stuff I can make, but barely, because that's what's fun to me, so I tend to get stuck fairly often, but rarely more than a dozen feet from terrain I can drive, or to where I've shoveled a path. I have a full size shovel, pick, and axe, to supplement my hi-lift and come-along. Given enough time, those tools can do a lot.
First, price matters a lot, and I shouldn't have to say the load rating matters a lot too. I don't bother with anything rated under 6K, but I have a 6K american made unit that will pull apart 2 chinese 8K units at once. If you buy a $60 and under unit, buy 2 and lubricate and test them first under a heavy load (put it in 4wd and park, then drag it up a gravel road). You should pull out their soft metal bolts, replace them with grade 5, and lube everything. I've had many cheap ones fail the very first time. The last two cheap ones I bought were very sturdy, but the ratchet catch was mounted so it engaged almost perpendicular to the drum and let it flex by under what I would guess was only 1/4 of their rated weight. I drilled new holes about 1/2" from where they did, and replaced the rubbery bolts with grade 5, then they worked great as backup to my good one. I've bought $160 units that worked flawlessly for years before wearing out.
I just ordered, but haven't tested yet, an ARB hand winch. It has a low rating of 5300 pounds, but can pull any length of cable through itself, so there's no reason not to use a snatch block to double the rating, or two to triple it for that matter. I'll have 200 feet of cables and chains, 2 snatch blocks, and a rating as high as 15,900 pounds depending on how I set it up. If you don't know how that works, ask and I'll explain it. Yes, it will take a lot of time to move very far, but what else do you have to do when you're stuck? It's worth noting the ARB hand winch would not work for some of the undercarriage repair tricks I've heard of but never done.
Second, on the comments that you can get an electric winch for $400: that's like saying cheap 37" tire prices and thinking that's all it will cost to put them on your stock jeep (without mentioning the cost of the lift, wheels, etc.). In reality, unless you already have a winch mount bumper, that's a $400 paper weight.
The cheapest I've ever mounted a winch (I won a winch as a door prize once, so add your $400 crap winch on top of this cost), was when I bought a hidden mount kit for about $300, wires and other hardware probably around $50, then spent an entire weekend modifying my rig to get it working. Even if you go with a hitch mount and you already have a rear receiver, the mount is $100 to $200, and the wiring is another $100 to $200. That ignores the fact that you should have a dual battery setup for winching, but can risk getting by without it. Keep your lights off, the heater fan off, and rev the engine 5 minutes at 2,000 rpm after every one minute you winch. Do not ever shut your rig off while winching out, or you risk needing a jump start in the middle of a mud bog.
I would say, if you're good at bargain hunting and modifying, you can get a minimal winch mounting setup in for $300 to $400, so call it $700 for the cheapest winch that is about as reliable as a free flashlight. Would you go in a cave alone, with only a free flashlight to find your way back? Okay, you can walk out of the woods when your rig is stuck, so that's a bit dramatic, but I'll still say you need to buy a hand winch on top of your electric anyway.
Contrast that with $250 for a quality hand unit and some chains and cables. If you aren't strong enough to run a hand winch for an hour or two, and do some digging and jacking, then don't go out alone (I don't anymore, so I'm not judging; I'm giving the advice I use myself).
For my current jeep, to get a winch mounted on the front, I bought a $1500 ARB winch mount bumper, then paid about $700 to have it installed (optional), on top of the $800 I spent on a quality winch that will actually work more than once. I've had several of those $400 winches over the years, and one of them worked many times, but I could never trust them, and some didn't work when I opened the box. DO NOT install a cheap winch without running it on the shop floor first, because you have about a 50% chance you'll be boxing it back up and sending it back. I also don't recommend mail ordering a cheap winch because I hate return shipping processes. Pay $20 bucks more and buy your crappy winch somewhere you can stomp back in and swap it the same day.
You should have a quality hand winch AND a hi-lift jack as backup to your electric winch anyway, unless you never, ever go out alone. Or, I suppose, unless you're comfortable with the idea of walking out of the woods and getting help. Just my 2 cents. Have fun wheeling!
