roof top tent
1K views 3 replies 4 participants last post by  rockhounds4x4
Can I put one on a 2001 Jeep Grand Cherokee? I have been camping for years (tent camper) and see them being put on other vehicles. I would be going to a place and setting up. Any particular brands? Disadvantages? I'm single so just me.
My biggest concern would be how much weight the roof and rack can take. I'd have to look into it but it seems like it's rated at 150 lbs. I'm not positive on that though.
The owner's manual states 150Lbs. However, it should be noted the mounting holes under the roof rails are known to rot. If you poke around with the search function above, and the Google machine, you will find folk that have made purpose built tent platforms.
In fact a thread was just recently started on this very topic:
You will also find guys that use a 3rd cross bar in the center to prevent sag. I run 2 universals on the ends and then a factory cross bar in the center under my extra large cargo basket. Mine did not come with cross bars, hence the universals:
When I got the cargo basket, I decided to add a 3rd. I went OEM as it has a lower profile than the universals, so I worked perfectly with the contour of the roof. I found a used OEM cross bar from deadjeep.com, although eBay or your local bone yard probably has them as well.
Reactions: darkstarmoto
