1 - 15 of 15 Posts
crumb
Discussion starter · #1 ·
I am getting the P0700 and P0740 codes and feel like I just need to replace this thing. I want to get started tomorrow but have been reading that I need to do this quick learn thing once the new TC is in there.
Can anybody tell me what this is or if it is necessary?
The FSM told me a quick learn was required after my recent 42RLE repair too. The only thing I did was to reset the computer by disconnecting the negative lead from the battery and holding it against the positive cable for 20-30 seconds. That discharges/resets the learned parameters inside the computer. My transmission was perfect after I was done without having done the quick learn process.
The quick learn is done with a higher end scan tool or drb or Witech. What it does is applies all the clutches in a sequence for the computer to know how much time it takes fill the clutch circuit. Its an electronic wear indicator for the transmission. Also some Chrysler/Jeep transmissions have a torque converter break in procedure using again a high end scan tool drb or Witech. Just some things I have to do when doing transmission work at the dealership. Do you have to do theses procedures Mother Mopar says yes. But my experience yes and no . If you have crapping shifts after repairs then I do a quick learn. If my shifts are fine then nope.
Discussion starter · #5 ·
What's the trick to removing those top 2 torx head bolts where the transmission connects to the engine? They are really on there. I really don't want to damage the torx head on there.
Those are tricky, but as long as you are using the correct size torque socket well seated - meaning straight and all the way on - you won't damage the bolt. It does take a crazy combination of extensions and u-joints on the ratchet to get to it. It also helps a lot if you lower the tranny a bit after you remove the cross member.
No trick, just make sure you're using the correct E-12 e-torx socket. If you're using a string of 3/8" extensions to reach the e-torx bolt with a 3/8" ratchet wrench, try switching the ratchet wrench to a 1/2" with a 1/2" to 3/8" adapter to give you more leverage against the bolt.
Discussion starter · #8 ·
It sounds like I just need to crank harder on those suckers. I also have it held up by the engine so I am going to put the weight under the transmission to see if that tiny bit less stress may change anything.
Some guy on YouTube said he took a punch to the center of the etorx bolt and hammered on it and that made it easy to remove. Not much room to try that but I am almost ready to try anything.
Discussion starter · #12 ·
I am trying to find the torque specs for those 2 e-torx top bolts and the specs for the 2 side bolts for mounting the bellhousing back to the engine block. Does anybody know what those would be?
28 ft-lbs. That's actually the spec for the manual transmission but that should be fine for the automatic mounting bolts too, they're bolting to the same thing... the engine. I couldn't find the ft-lbs. for the automatic either when I recently repaired my 42RLE.
Discussion starter · #14 ·
I got everything all back together today and it seems to be running well. I had a whirring noise coming from the transmission when I ran it initially after getting it back together but only in park or neutral. It almost sounded like a remote control car servo. I went for a drive and came back and the whirring noise was going on and off. I drove it later a little longer and now the noise seems to be gone. I will keep an eye on it. Hopefully it is gone.
Is that sound something attributed to the new torque converter breaking in?
Perhaps the ATF just needed to completely circulate. Check your ATF level again now, make sure the engine is running while you check the level. My 42RLE took a couple more quarts than I expected after having it apart earlier this year, more drained out than I expected.
1 - 15 of 15 Posts
