OK so I had the click click no start yesterday and called in a tow truck, and right when the truck showed up it fired up . Anyways , went and bought a new starter from Auto-zone 104 + 60 core...crawled underneath the driver wheel and that thing looked almost impossible to remove I mean the exhaust pipe in the way then the big solid cross member that runs from side to side. I have the shop manual but it doesn't say anything as far as what needs to be removed in order to remove the starter, Also did some search on here and noticed that the wire connector on the solenoid is corroded which might be the problem. Either way, how in the world do you take this thing out
........HAAAALP.
Thanks.
Thanks.
