So I've searched forums here and in other sites and seeing some people having similar issues, and one of the Ram forums a guy ended up needing a new battery so that is what I was suspecting. Here's the rundown of my issue and what I've done so far. Just got this Jeep a couple of weeks ago used, and have had this problem since I've tried using the remote start.
The place I got the battery from was wondering if I have a parasitic load issue going on that is draining the battery ever so slightly enough to trigger the "low battery" shut-off of the remote start module. I will check that next. Not sure if I have a real issue or maybe just a programming issue with the Jeep itself? I heard some Cherokee guys there was a TSB for programming issues to the BCM or whatever has the programming for remote starting. Before I take it to the stealership, I'd like to narrow it down first.
- If I initiate remote start (with either fob), truck will flash, and ignition will kick on, then it will crank over for maybe 1 second and then shutdown. Won't allow me to try again until I get in the car per the way those are programmed.
- Get in car and get the dreaded "Remote Start Disabled" message which doesn't narrow it down that much really
- Jeep will fire up just fine when starting the usual way (key in vehicle and using the start/stop button)
- If I drive the Jeep around for a bit and park it, then remote start it, it will fire up just fine.
- Suspected battery is getting too low when remote starting after sitting for a while, so put my meter on it and let it sit. Remote started and recorded the min voltage point of 9.63V during a "failed" remote start
- Next morning I tried it again and recorded a min voltage of 9.79V on a SUCCESSFUL normal start.
- Decided to replace battery even though it is only 3-years old and battery tests "good". Put in an Oddysey Performance AGM battery since dealer had my battery on backorder.
- Still getting same remote start failures. Even went to lunch today and had a failed remote start when leaving for lunch, tried it after we got to lunch and it was successful, but then after lunch (maybe 45 minutes max later) and the remote start failed again. Always the same message of "remote start disabled". It's a little chilly today but not THAT bad; around 45F at lunch.
