1 - 10 of 10 Posts
jbrink
Discussion starter · #1 ·
Windows aren't working the overhead temp gauge reads -- and engine stalls after 2 seconds. Every light around the gauges come on. Power locks, mirrors, and seats work until I turn the ignition on. When I turn the key on the PCI bus stops communicating. Any ideas on what to check or where to go from here. Originally I thought it was the skim. Everything was fine and I parked. Went to start and it stalled.
Discussion starter · #4 ·
I took the boot off'of the door side and kinda pulled on all the wires. None were broken in half. Where do the wires go? Do they go to the bcm? I wanna try to check the continuity with a mutlimeter.
I just put a new battery in and new battery terminals a few months ago. They are shiny new. I'll check the ground wires where they bolt to the body/frame or wherever they go.
Discussion starter · #7 ·
Just a little update. Held the 2 buttons on the EVIC and turned it on. J1850 no bus comm. Pulled codes from the data port P1686 no skim data. I'm gonna check the wires in the door boot again. Any one know where they terminate cause they might be broke internally because the insulation isn't broke.
1 - 10 of 10 Posts
