Re:
Ok, I'm officially confused. I thought I was good to go based on the info I found in my FSM:
But when looking for some more info, I came across this post which shows a screenshot similar to mine but with completely different numbers!
Is there really that much difference in PAG capacities between a 99 (the WJ in that post) and my 04?
And while I'm here, I'll mention that I'm getting ready to replace every AC component, except the evaporator, so I feel as though getting the right numbers is critical given how drastically different these capacities are between two screenshots.
This is from a 2004 Service Manual for the WJ:
REFRIGERANT OIL
DESCRIPTION
The refrigerant oil used in R-134a refrigerant systems
is a synthetic-based, PolyAlkylene Glycol (PAG),
wax-free lubricant. Mineral-based R-12 refrigerant
oils are not compatible with PAG oils, and should
never be introduced to an R-134a refrigerant system.
There are different PAG oils available, and each
contains a different additive package. The 10PA17
compressor used in this vehicle is designed to use an
ND8 PAG refrigerant oil. Use only refrigerant oil of
this same type to service the refrigerant system.
STANDARD PROCEDURE - REFRIGERANT OIL
LEVEL
When an air conditioning system is assembled at
the factory, all components except the compressor are
refrigerant oil free. After the refrigerant system has
been charged and operated, the refrigerant oil in the
compressor is dispersed throughout the refrigerant
system. The accumulator, evaporator, condenser, and
compressor will each retain a significant amount of
the needed refrigerant oil.
It is important to have the correct amount of oil in
the refrigerant system. This ensures proper lubrication
of the compressor. Too little oil will result in
damage to the compressor. Too much oil will reduce
the cooling capacity of the air conditioning system.
It will not be necessary to check the oil level in the
compressor or to add oil, unless there has been an oil
loss. An oil loss may occur due to a rupture or leak
from a refrigerant line, a connector fitting, a component,
or a component seal. If a leak occurs, add 30
milliliters (1 fluid ounce) of refrigerant oil to the
refrigerant system after the repair has been made.
Refrigerant oil loss will be evident at the leak point
by the presence of a wet, shiny surface around the
leak.
Refrigerant oil must be added when a accumulator,
evaporator coil, or condenser are replaced. See the
Refrigerant Oil Capacities chart. When a compressor
is replaced, the refrigerant oil must be drained from
the old compressor and measured. Drain all of the
refrigerant oil from the new compressor, then fill the
new compressor with the same amount of refrigerant
oil that was drained out of the old compressor.
The A/C Compressor I got for my 2003 WJ with the 4.0 liter engine is made by Denso and is Model Number:
471-0400. I don't know for sure weather or not the WJ's with the V8 engines have same compressor etc., but there is nothing in my 2004 SM that indicates there is any difference in the PAG Oil Capacities Chart.
I got a brand new A/C Compressor from Rock Auto and it included the A/C Compressor Clutch.
