Just a brief history- 1998 TJ 4.0l Auto- I have about 15 k miles on the new crate engine installed a little over a year ago, by me. Distributor, cap, rotor, plugs, wires, cam sensor/pickup coil, crank sensor, oil pump, were all replaced at the time. I recently had the Jeep down for about a month, long story that I won't get into now, but I think the only relevant info about that ordeal is that I unplugged basically every sensor and harness under the hood, pulled the battery and hooked to a tender while the Jeep was down. Anyway, after putting it all back together, I've been having random issues with a P1391 'Loss of Cam or Crank' code. As stated above, both sensors were replaced last year during motor install, but I went ahead and changed them both again anyway. Cleared and tried again, same issue. I pulled the distributor and made sure it spins smoothly and the gears looked ok (just because I didn't know what else to check) but it appears to be operating correctly. I had a spare cap and rotor so I swapped those out as well.
Something of note, it runs a little rough now when cold, and it never used to, even with the old engine. The rough running doesn't seem to be related to the CEL though because usually when the light comes on the Jeep is running perfectly. It just seems random, is what I'm trying to say. The only thing that I can come up with that makes any sense is maybe a loose or bad ground, so as soon as I can get out there today (I'm at work but the weekend shift DOES have it's advantages !!!) I'm going to look at that. I did have some of the ground wires off when it was down this last time. Oh, and just some added info...I drove it to work and home twice, about 200 miles, and it did fine, no codes or rough running/missing. This morning when I started it up, it was missing like crazy and the CEL came on, so I cleared it with a code reader, restarted, and it did fine the whole way to work...
Sorry for the long post, just trying to include as much relevant info as I can.
Any input would be greatly appreciated
