Normal oil pressure for 4.0
13K views 11 replies 10 participants last post by  hayzer
My oil pressure on my 99 4.0 seems low it is at about 20 at idle when warm and go to about 30 or 40 when driving. When outside temps ar higher it seems to be at the lowest. What is considered normal. I here some say put heavier oil in the summer, The garage is putting 5w30 when oil is changed.
I have Mobil 1 5W 30 in my 2000 4.0 from the winter and I still get 30-40 idle and 40-55 cruisin. Swappin it out for the Mobil 1 High Mileage 10W-30 in a month or so, hoping itll remedy the steady drip i got from goin syn.
you got more pressure at hot idle than most. my 99 runs 22psi at hot idle. these 4.0l can take almost 6-8psi before they will knock. and i personally have known a high mileage xj that was at 10psi hot idle for years with no ill effects. so as long as the motor is taken care of you should be at 20 hot idle for years! mike
