I realize this topic has come up quite a few times but here goes. Starting to get a chill in the air in the Carolinas - and popped on the heat for first time in a while and just got cold air. I did quite a bit of searching and trouble shooting on this and other forums.
AC works fine, the heat isn't as cold as the AC, but still blows cold. Blows air with no problem from all modes/speeds (defrost/floor/etc) but cold all around.
Here's what I've tried to rule out:
I was able to peak at the/a blend actuator motor by the steering column, looks like the white part is moving when I switch between air location (defrost, feet etc). I'm assuming this is working?
From what I've read the this possibly leaves the blend door behind the glove box possibly not working or a broken door/pivot? I can hear a click behind the glove box, closer to the center console when switching from cold to hot temp. Is there anything else to try other than cutting a hole in my heater housing or removing the whole dash/heat system? A while back I got P0455 evap leak code, but it went away after restarting and hasn't come back or won't show on code reader. Not sure if that may have anything to do with it.
Any help would be greatly appreciated, I'm hoping I don't need to remove the dash and or heater components!
- Heater hoses to firewall are equally hot once up and running.
- I flushed the heater core just to be safe, was pretty clean, no change.
- Topped of coolant (wans't low, no leaks) ran to make sure no air in system.
- Thermostat seems to be fine - getting continuous mid reading on instrument cluster once warm.
- Removed temp controls from the dash, checked wire harnesses to make sure they weren't loose.
- Checked the heat resistor plug behind glove box to make sure it wasn't loose.
- Ran manual collaboration of blend door I read about in a TSB - turning cold/hot air in succession with power on, no ignition - no change.
