i need some help finding the plug and bypassing the nss.
what i have done is used the frame and 4.0 and slid it under the body of a 97 4 cylinder manual 97.
the 4.0 was an automatic.
i have swapped the wiring harness in the engine bay for the 4.0.
i can pull the starter relay and jump the pins and the jeep will turn over. however i cannot start it with the key.
the wiring for the 4 cylinder is still under the dash. i have not swapped that part out yet. i did unplug the wires going to the clutch. i was thinking since my wiring was for a 4.0 auto that maybe the clutch pedal switch was stopping it.
maybe i should take the harness our from under the dash and put the 4.0 harness in. not sure.
i found the plug that i am guessing that went to the transmission. it had four wires. i took a jumper and tried to jump some of the wires and i blew a fuse to the lights. i guess back up lights.
any help i will appreciate it allot. thanks
