I’ve been battling a cooling system issue where coolant gets pushed into the overflow tank but doesn’t always return after cooldown. Jeep doesn’t overheat. Here’s what I’ve done so far:
- ✅ Replaced radiator (new)
- ✅ Replaced water pump, thermostat, and temp sensor
- ✅ Verified no overheating — coolant hits ~224°F max
- ✅ Fan kicks on late (around 223–224°F);
- ✅ Radiator cap replaced with Mopar 4596198 and Stant 10234 — no change
- ✅ Overflow hose replaced
- ✅ Burped the system multiple times (nose uphill, cap off, watched bubbles)
- ✅ Block test with Gold Label kit — no color change
- ✅ No white smoke, oil is clean, system passes pressure test
