MOPAR or Ms-5931 Compliant Power Steering Fluid?
84K views 42 replies 20 participants last post by  Mr. Bitey
Autozone sells their store brand PS fluid, which states that it meets MS-5931 standards. Is it okay to use that or should I be buying the more expensive MOPAR fluid? Anybody have a favorite fluid? Same question for brake fluid....
#19 ·
WiCkeDuDe said:
Most dealers prefer to use atf4+. The bulletin from mopar say only to use power steering fluid. It does not have to be mopar. I have used both and seen no problem with either fluid. I run the royal purple maxez fluid in mine with no issues at all.
Thats because power steering fluid and atf fluid are pretty much the same thing. I dont understand why Chrysler said not to use ATF+4 in the PS system.
#22 ·
Dang guys.... Originally mopar PSF MS-5931 was the recommend part and what jeep put in the earlier WJs, later down the road jeep had a service bulletin that made ATF4 supersed the PSF But not for WJs.
System check to see what's currently in there. Gold looks like oil = PSF
Red/Pink = ATF4
Brown/Milky/Black/Clear = drain & flush system ASAP after proper flush refill with MS-5931 or compatible fluid that meets spec (I like AmsOil)
#29 ·
I asked for MS-5931 for a 2004 GC Grand Cherokee 6cyl at the Baton Rouge, LA dealer and was handed MS-9602, which does not state anything regarding compatibility on its label. Mopar does not show any power steering fluids at their site. I need reliable info, understanding that an incompatible fluid could cost $$$ in repairs.
#33 ·
******Supposedly****** MS9602 supersedes MS5931 reading other forums. But if we want to be literal here, then don't use it. Find one that has MS5931 spec. I'll keep digging for the supersede info
Edit: Looks like MS9602 does supersede it, but after just taking an extra minute of searching, found this post on our very own subforum :)
https://www.jeepforum.com/forum/f13/p-s-fluid-questions-ms5931-919291/#post8426766
[snip]
Read this on WJJeeps:
Mopar®P/N 04883077 Hydraulic fluid / Power steering fluid (MS5931)
MS5931 IS THE ONLY FLUID THAT CAN BE USED FOR THE POWER STEERING SYSTEM. NO EXCEPTIONS!
Important note:
The factory fill power steering fluid for all 1999-2004 Grand Cherokees is a unique fluid, MS5931. ATF+4 (MS9602) should not be mixed or used as a "topping off" fluid on the Grand Cherokee WJ. All WJ models should be serviced using ONLY the special MS5931 fluid. ATF+4 is NOT an approved Power Steering Fluid and should never be used under any circumstances. Note that all fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
I didn't know this when I first got my Jeep and I'm pretty sure I topped it off with ATF+4. Am I screwed? I haven't had any issues at all and it's been about a year and a half. Do you all adhere to this pretty well? Any experience deviating from this? Where is the best place to buy MS5931?
[/snip]
