Moog Tie Rods come pre greased?
41K views 21 replies 19 participants last post by  Satrebil
I just finished swapping the Tie rod ends and see the moog parts have some greas3 where the fitting goes. Do these come pre greased or do I have to throw some in there? I dont want to over grease them and rip the seal if that is even possible. Going to install everything and check back for an answer. Thanks!
Tie Rod Ends
Right Outer (Steering Arm To Steering Arm): ES3472
Front Left Outer: ES3473
Right Outer (Pitman Arm To Steering Arm): ES3474
Front Left Inner To Pitman Arm: ES3475
Adjusting Sleeves
Steering Arm To Steering Arm: DS1452S
Pitman Arm to Steering Arm: DS1453S
Courtesy of ChrisHager
Parts are usually "shelf-greased" so they won't freeze up in storage, but I wouldn't consider it a useful service lube. And, it's cheap grease.
Once I've got the parts in and the boots on, I'll be under there with a grease gun (loaded with red moly chassis grease) in one hand and a clean(ish) rag in the other - gently pump in grease through the zerk until the grease coming out from under/around the boot goes from amber to red.
Just don't get stupid with pumping - you don't want to blow out the boot!
Thanks! I did about 5 pumps which looked like more than enough when I pumped some on a napkin.
Yeah! Those were the numbers I got. RockAuto had them the cheapest from everyone and I even used a 5% off coupon. $99.33 shipped.
If worn tires due too poor toe in alignment are still used after new TRE, would I still experience the 50-60mph very slight shake, or should it cure it regardless after an alignment with the worn tires?
I read a lot of posts where people were saying to bang the tie rod end on the pitman arm off but I wasnt comfortable being the steering gear might get damaged, I used a tie rod end puller. I centered it where I was able to use about 3 feet of extensions with a ratchet from the top and it worked like a charm.
Mine needed to be greased. Just enough to puff the boot out a little.
Sent from my iPhone 6 using JeepForum
