It is an I6, not V6. may seem obvious but if you have a V6 it is not a 258ci, though typos abound.
I have a 1984 and it is at the front next to the top radiator hose. my 1981 has it at the back of the engine near the bulkhead on the manifold side.
My wiring diagram says Purple with tracer for the temp sending unit, solid purple for the oil pressure sender.
The oil pressure sender is low down behind the oil filter on the side of the block.
My 1981 has the 2 wires in the harness coming through the bulkhead connector and then splitting off, one passing over the top of the engine to the sender. However the 1984 has the temperature sender wire continuing in the harness further forwards.
The temperature sender is unmistakeable once you see it, it is not very tall, quite slim and is in a water passage. If in doubt look it up on Qadratech and then find a similair looking device on the top of the engine. It is usually on top as hot water rises.
