Jeep not starting
About a year ago, we had a mobile mechanic come and take a look at the 1997 Jeep Grand Cherokee Laredo V8 5.2. He found one issue. We recently had a similar issue but without the overall problem. If your in a hurry jump to the conclusion.
Last year:
We were having the same problems as you guys. One random day the Jeep stalled out in a busy intersection while my wife was driving. She had to push it on her own (no good Samaritans) to the corner gas station. The thing would not start and we had to have it towed home. We had the mobile mechanic come out and he came up with short in the PCM that was causing the Jeep to lose power and stall. It was also having transmission issues. The '97 Grand Cherokee would not shift out of first into second. I can't remember all of the issues, but we went to the junkyard and found a nice match for the PCM and did the swap.
Recent:
This last Memorial Weekend, my wife and I went camping in her Grand Cherokee. We got to the location, went out for drives and had no issues. We packed up and began our decent back to civilization, the Jeep wouldn't start. There was a rapid clicking in the passenger side dash. There was no power. Went and grabbed the jumpstarter, hooked it up and started right up. Immediately, the Grand Cherokee stalled out. We tried this several times and got to the last crank on the jumstarter. Then decided to keep a foot on the gas and hit it!!! We made it all the way home (100 miles or so). Praise Jesus, we had mostly green lights and a clever "Neutral" "REV" California stop! We pulled in the driveway, turned to back in and BAM!!, DEAD!! would not start. I charged the jumpstarter and check out some forums on the issue. One said to check for a corroded positive cable that is causing the clicking due to low voltage. I bought a positive cable because I did see the lights brighten a bit when I was moving the cables around. I went out and gerry rigged the new cable on to the system (with the old cable removed) and proceeded to fail to start. I regrouped and googled "jeep grand cherokee won't stay running" and found this post that said to change the IAC (Idle Air Control). I disconected the IAC, didn't start. Took the IAC off and cleaned it with brake cleaner, Jeep started, but wouldn't stay on. When I held the gas and let it out gradually, I was able to get it to idle. On a whim, I took the IAC out and started the Jeep without it. The jeep started right up and didn't stall. It had great suction where the IAC should be. I placed the IAC back into its slot while the Jeep was running and it expectedly stalled within seconds. Went to the local auto store, replaced the IAC and runs beautifully. I don't know how the whole system lost power and wouldn't start, but as for now it is starting and running. I will hold on to the positive cable, just in case.
Conclusion: Thanks Guys
Transmission shifting problems = PCM shorting (replace)
Not starting, stalling out = IAC (Idle Air Control) replace
