While installing a subwoofer amp today, I found this. It might be helpful for someone else:
Infinity Audio Wiring
1999-2001 Cherokee Infinity Sound System
Head Unit
FUNCTION PIN WIRE COLOR
Accessory 12 Volt 2 RD/WT
Constant 12 Volt 1 PK
Chassis Ground BK (female spade)
Power Antenna
Remote 14 D.GN/RD
Illumination 4 BK/YW
Dimmer 3 OG
Left Front + To Amp 11 D.GN
Left Front - To Amp 6 BN/RD
Right Front + To Amp 10 VT
Right Front - To Amp 5 D.BU/RD
Left Rear + To Amp 13 BN/YW
Left Rear - To Amp 9 BN/L.BU
Right Rear + To Amp 12 D.BU/WT
Right Rear - To Amp 8 D.BU/OG
FUSE VALUE FUSE LABEL FUSEBOX LOCATION
15 AMP #17 PASSENGER SIDE DASH ENDCAP
15 AMP #16 PASSENGER SIDE UNDER HOOD
Power Amp
The Infinity amplifier is located under the rear seat and can be used if an aftermarket stereo is installed. It is protected by a 20 AMP fuse labeled #26 that is located in the fusebox under the hood on the passenger side.
Infinity Amplifier Wiring
Constant 12 Volt 1 VT
Constant 12 Volt 2 VT
Left Front Spkr + 4 L.GN/VT
Right Rear Spkr + 5 TN/RD
Left Rear Spkr + 6 WT/RD
Chassis Ground 7 BK/L.BU
Chassis Ground 8 BK/L.BU
Right Front Spkr - 10 L.BU/BK
Right Front Spkr + 11 L.BU/RD
Left Front Spkr - 12 BN/RD
Right Rear Spkr - 13 TN/BK
Left Rear Spkr - 14 WT/BK
Left Front - Input 15 BN/RD
Right Front - Input 16 D.BU/RD
Right Rear - Input 17 D.BU/OG
Amp Remote 18 D.GN/RD
Left Front + Input 19 D.GN
Right Front + Input 20 VT
Left Rear + Input 21 BN/YW
Left Rear - Input 22 BN/L.BU
Right Rear + Input 23 D.BU/WT
Wiring at Speakers AT SPEAKER WOOFER COLOR
TWEETER COLOR The door tweeters are wired in parallel with the door woofers.
L/F Speaker + D.GN/BK (97) D.GN (98-01)
Tweeter L.GN/BK
L/F Speaker - BK/RD L.GN/RD
R/F Speaker + L.BU/RD L.BU/RD
R/F Speaker - L.BU/BN (97-99) L.BU/BK (00-01)
Tweeter L.BU/BN (97-99) L.BU/BK (00-01)
L/R Speaker + WT/TN (97), BN/YW (98-01)
L/R Speaker - WT/BK (97), BN/D.BU (98-01)
R/R Speaker + TN/RD (97,99-01), D.BU/WT (98)
R/R Speaker - TN/BK (97,99-01), D.BU/OG (98)
Video and Navigation Wires FUNCTION LOCATION COLOR
Vehicle Speed Sensor Pin #27 of 32-pin gray plug at PCM located under hood LH side WT/OG
Reverse Light ( + ) Pin #16 of 40-pin black plug at junction block under LH kickpanel BN/L.GN
Parking Brake ( - ) At parking brake switch GY/BK
Brake Light ( + ) At brake pedal switch WT/TN
JB
Head Unit
Power Antenna
Remote 14 D.GN/RD
Dimmer 3 OG
Power Amp
Tweeter L.GN/BK
JB
