Well. You just paint them. I washed them, and then rubbed them down with alcohol and made sure they were dry. I did not sand them, which I think if I were to do it again, I probably would take the time to run a light sanding over them.
I went a bit over board on protection. I taped them off, then placed card stock paper between the flare and the jeep, and then used plastic.
I used Rustoleum direct to plastic paint. No primer necessary. I used black gloss. Others like Krylon Satin. To each his own.
Anyways....a couple of pics..
Prep work was the longest time suckage.
Front Prep
Rear Drivers
Done.
