Hey guys would a 6.1 intake fit the 5.7? And do the heads fit? Im curious
thanks man seems like a lot of work haha, i just like the look of the intake manifoldYes, it'll fit (almost everything is interchangeable) but, on a 5.7 it is not as efficient as it is on a 6.1. Some time ago one of the Automotive magazines (I think Hot Rod or Mopar Muscle) did a test using the 5.7 automobile, the 5.7 truck, the 6.1 and Edlebrock 4bbl. carb manifold, and on the 5.7 the one that comes on the Charger, 300C, Magnum and our Jeeps gives the best all around performance. If you're going to put the 6.1 heads on it, they'll fit too, but again won't work as well as the 5.7's do on a stock/relatively stock 5.7. If you go to a larger displacement, then you'll be in good shape though.
If you do something like this you'll need to put the 6.1 headers on it, and some sort of performance cam. You'd probably then want to ditch the 5.7 MDS valve lifters. You should also raise the compression ratio, as the combustion chambers in the 6.1 are larger which lowers the compression ratio on the 5.7. Overall, unless you go big, you should stick with 5.7 stuff and maybe think of doing some mods. to it. It's not too difficult to pull another 100-150 hp. out of a slightly modified 5.7.....see my mods. in my signature below. Right now I am about done and am running about 120 more hp. than stock and also now get 22-23 mpg on the highway.
