Ok, I have been working on my CJ quite a bit lately to cure the problem of it running rich and smelling terrible every time I drive it. It's an 81 CJ7 258 with 4.0 head, HEI, and Weber 38 DGES. I am in Houston so basically sea level. The timing is roughly 10 degrees. I have adjusted it slightly several times to see if it helps, but I have not observed significant impact. Historically I have run as much as 18 degrees with the HEI setup and it ran fine. For purposes of getting the carb setup right I wanted it closer to the factory setting which is 8 degrees +/-2.
Background. I had tons of problems with the stock carb for years. Finally purchased this Weber carb 10+ years ago (don't remember exactly how long). I have a Carter electric fuel pump. The Jeep ran night and day better than the stock carb so I was happy and didn't care that it ran rich. Did a 4.0 head swap probably 5 years ago. Runs great, but still rich. I never really had enough time that this project made it to the top of the list. Recently that changed so I am tackling it since the carb needed a rebuild and had run horribly the last year or so. The accelerator pump was leaking gas so it helped make the rebuild happen. After the rebuild the Jeep runs better, but still rich.
I had some extra jets (long story) so I was going to run through the tuning guide and see if I could make it run. After some tinkering, I think I need different jets than I have in my possession. Technical help from weber is lacking so I am hoping some folks here might have some experience to help.
Turns out there are 2 different places to get weber carbs. Redline and weber carbs direct. Redline has significant technical information and help. When I called and was talking to them they asked me what color my electric choke was. Once I told them they let me know that I did not have their carb, but rather a "rip-off" of their design and to call weber carbs direct. :frown2: I have called weber carbs direct and am waiting to hear back, but googling leads me to believe I won't get much technical help. I wish I had known this when I ordered. I remember several places selling them and just picked one.
I do have a holly fuel pressure regulator so fuel delivery is right around 3 psi.
With the jets that the carb came with (45 idle jets, 145 main jets, and 170 air jets). It will not run without the idle speed screw opened up several turns which allows the progression port to be exposed. Due to that there is no way to adjust the idle mixture screws to in a way that lets me know if I need larger or smaller jets. However, it appears I need larger jets based on this. I had 50 (primary idle jet) and 60 (secondary idle jet). I swapped those in and it is better. Still rich, but it will idle with the idle speed screw only open 1/2 turn (progression port is not exposed until roughly 1 turn (I verified this when the carb was off the Jeep because I knew it would be important later on). I know the idle jets should match. I need to order jets, but want to be in the ballpark and don't want to keep ordering jets over and over. With these jets in, I can get the jeep to run better/worse and by adjusting the idle mixture screws. The secondary side is obvious. The primary side not as much. This leads me to believe 60 is closer to the size I should need.
I know several on here have experience so I was hoping you might have some experience to offer some advice on jet sizing. I have found some mention in random places on the internet that saw I should be running 60's for idle jets, 150/155 for main jets, and 180 for air corrector jets. Other places seem to contradict this.
Below is what came in the carb new setup for sea level (supposedly)
Idle Primary 45
Idle Secondary 45
Main Primary 145 (they claim it should have been 137, but that is not what is stamped on it)
Main Secondary 145
Air corrector 170's
Additionally I have the jets below to play with
Idle Primary 50
Idle Secondary 60
Main Primary 135 & 155
Main Secondary 135 & 155
Air corrector 160's & 180's
Any insight to point me in the right direction would be helpful.
Right as I was finishing typing this I got a call from weber carbs direct. The guy I talked to did not seem too technical, but did try to help. His immediate solution was just to throw 40's in for idle jets until I pointed out it would not run on 45 and seemed to improve with larger (although mismatched) jets. They he said just to split what I had and run 55's. I am not sure there was much thought put into that. I can spend a ton of $$$ ordering a whole bunch of jets and playing with them, but I would rather have some idea or some input from those who have experience before doing do.
Idle Primary 45
Idle Secondary 45
Main Secondary 145
Air corrector 170's
Idle Primary 50
Idle Secondary 60
