Not always 'Easy', especially when you are reaching across with one hand to feel for Compression,
And trying to bump the starter solenoid with a jumper wire with the other!
Sprawled out across the engine like a big vulture pecking at the dead engine!
Anyway, you MUST find COMPRESSION STROKE.
Finger over the hole and 'Bump' the starter is the easiest way,
Since your Piston is coming up to TDC and the Balancer is showing TDC,
Your balancer probably isn't lying to you, they sometimes do.
Once you find COMPRESSION STROKE, where the piston is coming up and making pressure, STOP!
Use something to find TDC in the spark plug hole,
This should be TDC of compression, the piston all the way at the top,
Where the ignition fires and the piston starts back down on the "POWER" stroke,
That is were you want to locate the distributor #1 terminal and rotor at.
Think of it this way, SUCK-SQUEEZE-BANG/POWER-BLOW
That's
INTAKE STROKE (Suck) 1/2 Turn of the crankshaft, Piston Traveling DOWN, from top to bottom,
COMPRESSION STROKE (Squeeze) 1/2 Turn of the crankshaft, Piston traveling UP, from bottom to top,
For those keeping count,
That's one full rotation of the crankshaft in those two strokes, but only 1/2 turn of the camshaft/distributor. The crankshaft sprocket is 1/2 the size of the top camshaft sprocket, so one rotation of the crank is only 1/2 rotation of the cam/distributor.
BANG! (Power Stroke)
That's where the ignition fires, fuel burns, piston is forced DOWN 1/2 turn, from top to bottom by expanding heated gasses,
BLOW (Exhaust Stroke),
Piston travels from the bottom of the cylinder to the top expelling hot gasses,
For those keeping count, that is the SECOND TDC of the crankshaft, but only ONE revolution of the camshaft/distributor.
Then it all starts again,
SUCK, SQUEEZE, (one turn, you want ignition here) BANG, BLOW,(one turn)
SUCK, SQUEEZE, (one turn. you want ignition here) BANG, BLOW,(one turn)
SUCK ....
What we thing you have done is get the distributor in at the top of EXHAUST STROKE, 180 degrees of DISTRIBUTOR ROTATION out from where it should be.
Once you visualize the pistons NOT firing every revolution, then this is a snap.
A VERY GOOD argument for cranking on a dead engine until you understand how the
This is what knocks so many people out when they do this, and why I don't recommend most people change distributors unless they absolutely have to...
You CAN try this,
Get your rotor pointing at the #1 terminal mark on the distributor housing,
Pull the distributor up,
Turn the crankshaft ONE TURN, come back to TDC,
Then drop the distributor again.
Remember to back the rotor up about one terminal space (Counter Clockwise) and catch a camshaft tooth from there.
The rotor will move nearly a full terminal space as the spiral cut gear engages the camshaft, you have to compensate for this.
Remember to turn the engine TWO REVOLUTIONS once the distributor is dropped back in, come back to TDC after the SECOND REVOLUTION,
Check the rotor, if it's pointing at #1, the distributor got on the camshaft teeth correctly.
Try and start the engine from there,
Make sure you have fuel in the carb or use a little starting fluid.
It should just about fire right up.
If the rotor is only SLIGHTLY off #1 you can move the distributor housing to make the rotor point at the #1 mark you made.
If the rotor is a ways off, then lift the distributor, Try again to back the rotor up a little ways and try for a different tooth on the camshaft gear.
(you probably have TDC of Compression, so no need to turn the crank until AFTER you drop the distributor again)
After you have reset the distributor,
Remember to turn the engine crankshaft over TWO TIMES, and check the rotor.
This gives the oil pump drive a chance to seat, and you continue to come back to TDC OF COMPRESSION if you turn the engine two times for a check and another try if necessary...
