Years ago I remember reading about Jason Bunch and his rock-crawling lil' four-cylinder YJ. He seemed to do pretty well with it. One thing that helped him was he added weights to his flywheel. They called it an inertia ring.
http://www.4x4wire.com/tech/clutch/inertiaring/
I was intrigued by the idea. Not enough to spend the money at the time if I didn't need to just to add the weights to the flywheel, but it was always in the back of my mind. I had actually researched it at one time, but that's as far as it went. And if I remember right there were some clearance issues that required some trimming and grinding to make adding the inertia ring work.
My TJ is a 1998 with the 2.5/five-speed, 4.88 gears (dana 30 front Aussie/dana 44 rear Detroit locker) with 285/75/16" tires (~33"), and an RE 3.5" Superflex lift (& Bilstein 5100 series shocks if you're wondering). I love my lil' Jeep and the 2.5, and it is geared properly for the size tires I'm running, but sometimes you do have to downshift when on the highway on long inclines. And adding a lil' trailer to the mix just makes it worse.
Years later (fairly recently actually), Centerforce came out with a heavier flywheel for the four-cylinder YJ and TJ (and XJs and possibly their lil' MJ truck based on the same format with the 2.5). I said to myself "If I ever have to replace the clutch in my 2.5 TJ, I should try the heavier Centerforce flywheel".
Well this past July (2021) while on an overlanding trip with my TJ (& pulling my lil' homemade adventure trailer) the throw-out bearing started squealing in CO. Then it got worse in ID. I got it home 700 miles later SW WA) before it totally gave up (still hanging on by a thread, but is a ticking time bomb), but I guess now is the time since I've gotta get the clutch and all replaced, to decide to try the heavier flywheel or not.
So I'm doing it! I'm taking one for the team - wish me luck. Follow along and we'll see what happens. It ain't cheap, but we'll see if it is an improvement over what I've got now, or if it will be one of my more expensive mistakes. Here's what I ordered:
https://www.quadratec.com/p/centerf...force/billet-steel-flywheel-jeep-wrangler-yj-tj-jeep-cherokee-25l-engine-700478
https://www.summitracing.com/parts/CTF-DF201614
https://www.summitracing.com/parts/CTF-N1764 (you'd think the clutch kit would come with the throw-out bearing, but it doesn't).
I didn't do a thorough search on the subject of a heavier flywheel... but adding weight to a flywheel or getting a heavier flywheel isn't anything new.
http://www.colorado4x4.org/vbb/showthread.php?95681-adding-weight-to-flywheel
https://www.jeepforum.com/forum/f37/inertia-ring-swap-2-5-a-23919/
https://www.jeepforum.com/forum/f12/jeep-yj-2-5-tri-county-gear-inertia-ring-4433361/
https://forums.off-road.com/jeep-short-wheelbase/53512-power-2-5l-adding-bigger-flywheel-true.html
https://www.jeepforum.com/forum/f12/2-5l-inertia-ring-831179/
The old CJs with the 225 V6 engines came with a heavy flywheel, and they were known for being able to idle along with nothing stopping them, partially due to their heavier flywheel.
The parts arrived today. So next week I'll make an appointment with my tranny shop, and we'll get it done. I'll report back my honest opinions about what I think and how it drives after the swap.
