Headliner replacement Guide
151K views 103 replies 50 participants last post by  Jeff2018lat
hello, i have been looking to do this for awhile and i have found a couple good threads but some were lacking some of the pictures or information i was looking for before starting this project so i figured i would go ahead and do it myself and make a short write up on how to do it. The task seemed somewhat daunting at first but once you get started replacing the headliner wasn't too hard on my 96 zj.
Starting off i made a run to joann fabrics and picked up the material i chose for the headliner. I went with one of the cheaper ones i could find for around $10 a yard and ended up buying 4 yards, honestly you can get away with 3 but i didnt have the exact measurement on the length and didn't want to risk it being short
http://www.joann.com/home-decor-signature-series-vinyl-lexus-black/xprd780305/
that is a link to one very similar to what i bought. it was some sort of vinyl material
whatever you go with make sure it is 54 inches wide
After the fabric was bought i stopped by autozone and bought 3 cans of 3m Headliner adhesive for 15.99 a piece. I originally bought 2 and potentially it can be done with 2 but went back for a 3rd can about half way through the process because i did not want to run out.
So those are pretty much the supplies you need to get, everything else that is required you most likely already have in your garage like a shopvac, size 20 or 13/16 socket, Phillips head screw driver and im not sure what size but a torx head driver
here is a pic of the one that fit for me it shows as cr-vt25
starting off here is what the headliner originally looked like, ha you can see where i had used thumbtacks in the front to reduce sagging until i could finally get around to doing this.
the first thing i did was go around and remove all of the visors and handles using the torx driver
on the back handles their is a little plastic cover over a 3rd screw that you need to remove to get to the head of it
Next i removed the center console by first unscrewing the phillips head screw located at the front of it
once that is removed you will see the front start to hang down, the back part of the console is held on by like clips and you can slide it forward or backwards and it will slide or kind of pop off
here is a picture of what they look like
once that was removed i went to the back of the jeep
and started removing the plastic that was screwed in along the tailgate edge
this had 2 screws, one on each end and three clips in the middle that just pop out. i didn't realize this until it was too late but their are also 2 screws inside the rear light that you would have to remove the clear plastic cover to get to, i ended up breaking the part that attaches to the light because i thought it was just going to pop off to separate
after this piece was removed i used my 13/16 socket to remove all of the seat belts, i think a size 20 might have worked better but the biggest i had was a 19.
once they were removed i began popping off all of the plastic pillars that support the headliner piece up. Their are no screws involved with these they all use clips that look like this. I found its best to grab from either the top or bottom with a hand on the left and right side and slowly just pry it off. Dont forget to also remove the clips located in the center of the headliner in the back. i started them with a flat head screw driver and used pliers or just my hands to pull them the rest of the way
once all of them are removed the headliner should begin to separate from the roof and fall down. you then can maneuver it out of the back of the jeep.
for those interested here is what the jeep looked like without any headliner
Here is the headliner removed from the jeep. Once it was out i just peeled off the old fabric
Once it was off i began to clean the old foam off the of fiberglass piece. I used a vacuum and just use the hose to rub off the foam while sucking it up
some people say they rub the foam off and i tried this but i found that the vacuum seemed to get more off.
once it was complete i did run my hand (in a glove of course) over pretty much the whole thing while it was on its side to clear off any loose debris the vacuum missed. and ended up with
Once that was completed i grabbed my fabric and placed it over the top of the fiberglass piece and lined everything up. i left about 6 inches hanging off the front and back ends
and the width was perfect at 54 inches
i started at the front of the piece by folding the material over onto itself and applying the 3m adhesive to the fiberglass and to the material
then i pushed all of the material into place starting in and flattening it out towards the edges. The front i found to be the hardest because of the contours on the fiberglass
once this had dried for like 10 minutes i folded the material over itself again so now it is hanging off of the front of the piece and i would spray the adhesive in 3 foot increments spraying both the fiberglass and the fabric
i did this all the way down and ended up with
sorry that material didn't photograph well because it was dark when i was taking those last pictures
I will be finishing it today, what remains it cutting the edges of the material around the fiber glass and using an exacto knife to cut out the whole in the material for the handles and visors etc.
i will post pictures of the finished project tonight or tomorrow.
I hope this inspires you to fix yours because it really isn't too bad once you get started
feel free to ask any questions!!
okay, continuing from the other day..
I flipped the headliner over and finished trimming the edges of the now that it was attached to the fiberglass piece.
once they were all trimmed and the proper holes for things like handles and visors were cut out i folded the edges over and used my spray adhesive to attach the vinyl so that it would fold over the edges and give it a nice appearance. i didnt notice that it was like this on the original fabric but i figured while i was doing it i might as well put a little extra work into it so that it would give a a nice appearance. This was more tedious than anything.
And the curved parts of the fiberglass i would have to cut a line into the curve (Im not sure if that makes sense) but you can see the triangle like pieces that are attached to the topside of the fiberglass piece
now the headliner is pretty much complete but i wanted some of the accessories to look a little nicer so i decided to do some work on those. The first piece i looked at was the overhead console. it also had that old gray fabric and just was not very visually appealing.
i started by unscrewing all of the screws along the inside of the console, their were around 20ish. Once they were all out you can remove the light fixtures and the controls for your mpg stuff if you have them. Once that stuff was out the part that holds the sunglasses and everything along the center of the console was able to kind of pop out to separate. Once this is completed to can easily begin ripping off the old fabric and rubbing off the previous adhesive in pretty much the same manner of the headliner. Once it was cleaned to the best of my ability by just rubbing it was ready to paint.
So along with the center console decided to paint the handles, visor clips and the back clip things that push into the headliner. i ended up using a spary-on truck bed liner from autozone that i have used on previous projects
While i was waiting for this to dry i went ahead and maneuvered the headliner into place and used the plastic pillar pieces to hold it into position
Once the console and handles dried they ended up looking like this. You can see it has somewhat of a textured look and also some of the old adhesive that wouldnt remove kind of shows through but i dont think it looks bad. I thought about trying to use that fabric around the edge but it would have been very difficult for my level of fabric working ha and i think it wouldn't have lasted as long as i know this spray on liner will
okay so now that everything is done its ready to all be assembled. Everything went together very well and i am very pleased with the turn out.
here is a before and after
the only downfall to not using a fabric on the console is that you can see a tiny space between it and the headliner that the fabric would have filled, but this is only really noticeable from a direct side view with your head touching the ceiling
Overall it was a solid like 6 hours of work not including drying time, it was much easier then i thought it was going to be, even more so getting it out the more difficult/ time consuming part was prepping the headline so it was ready for the new fabric.
If i could do it again i would potentially go with a rubberized spray on bed liner just because it would be easier, probably provide better insulation, last forever and i would never have to worry about it dropping. So far this seems to be on their pretty well and i hope it last awhile.
i think i will end up buying black visors or potentially getting my current ones reupholstered. I am also contemplating painting the gray pillars the same color as the other plastics used in the interior
so now that you know how easy it is go do it!!
okay look at the center console i painted. i used a spray on bedliner from autozone and i think that is my favorite part of the whole thing. IF i could do it again i would really contemplate spraying the whole headliner piece with bedliner because it was would be cheap and so much less tidious then attaching that new fabric for the headliner. On the other hand the fabric does give it a nice look.
I have seen another thread where someone actually sprayed the whole fiberglass piece with bedliner
this has some pics of a xj
http://www.jeepforum.com/forum/f177/putting-bedlining-headliner-890996/
it looks okay. i saw a zj with it that looked alot better though.
#18 ·
i think you might be hard pressed to find a decent headliner at the junkyard. If you wanted to go for the stock look i would just buy the fabric and re-adheisve it yourself. But the bedliner probably would look as good and be much easier
#19 ·
I'm kinda digging the spartan, utilitarian, look of the ceiling with the headliner removed! I am kinda wanting to just bedliner the bare ceiling! Anybody got any pics of that?
#20 ·
above i post one of just the ceiling but no spray. i think that fiber glass piece provides a lot of insulation though. im not sure how it would fare without that 1-2 inches of fiberglass and the air in between
#21 ·
I've seen some spray on sound and heat insulation undercarriage stuff that is supposed to work pretty well, and it is paintable. I am wondering how it would work out to use some of that then spray bedliner over it..
#22 ·
Any feedback on how successful this is over time? I have re-done the headliner in my Cherokee twice and it needs another go. Never seems to last much longer than 18 months. Getting the right adhesives is hard due to European laws so I want bring some "Good Stuff" that will stand the test of time the next time i head over to Sweden. My ZJ needs the headlining done so I would use this as my trial.
#23 ·
Hey, this is a great writeup and I think I really like the material method over the spray method. I know this is an old thread, but I was wondering if it might be easier if you had a roller to roll the material on after you sprayed the headliner and the material? I'd also be curious just how awesome it would be to use Monsta-Liner since they now offer colors!
#24 ·
Jt - I have not had any issues with my headliner coming off since I have done this. I was fairly generous with the 3m headliner spray.
Monkey house - I'm not sure how you would fair using a roller. I would spray the adhesive on in 2 foot sections starting from the front and moving down folding the headliner over as it shows in the pictures. Might be worth trying out your way though of you think it will work well
#29 ·
Oh, ok. I only mentioned the roller because I thought somewhere you said you had a little trouble with the fabric in some spots. I didn't mean roll on the glue, just using a roller on top of the fabric, not actually touching glue. Great writeup though, really like it!
#30 ·
This past weekend, I opted for spraying bedliner on the headliner. I used the shop vac/small wire brush method to remove the old headliner backing material. I also ripped that nasty old fabric from the visors and overhead console. 'Sprayed the outside piece of the OC with bedliner too.
So far, I like the clean look, but I may go back and paint it grey...who knows? Time will tell.
Havent decided what to do with the visors. For now, I'll just reinstall them without the fabric....which looks pretty bad.
It's going to be nice being able to drive with a window down today. With that sagging headliner, I couldnt do that before. ( you guys know what I'm talking about, if your headliner is starting to come down )
I crave fresh air and sunshine anyway. That's the reason I buy Jeeps in the first place !
Before I reinstalled the headliner itself, I took a marker to the topside and told the story of my ZJ's history since the day I bought it. Mentioned the states it's visited, the duck and deer hunts, the boats it's pulled, the beaches it's driven on, saltwater fishing trips, the number of girlfriends and wives it's survived...etc. Told the mileage as of right now, the fact that nothing but Castrol has been used in it and a few other tidbits, including the fact that if someone was reading it, I'm probably dead because I have no intention of selling it.
#31 ·
Exactly why I buy jeeps! Oh and I also get debris from the foam coming down on me. Can't wait to get started!
