On the 5.7 it calls for a "special" tool to reinstall the pulley. All it really amounts to is a little longer bolt with a big washer on it. I found on the setup at my local industrial hardware place for cheap. You'll just need to use this setup to pull the pulley on far enough so the treads of the NEW BOLT (you'll need to get one) can pull it on the rest of the way. When you get the new bolt, check the treads real good, as I had to run a tap on the one I got from the stealer....after it started binding and wouldn't go smoothly into the crank. It might help to run the bolt in by hand BEFORE you install the new pulley....just to make sure it'll go in easily by hand. There is no keyway in the crank or woodruff key, so the pulley can go on any old way. If you're planning somewhere down the road to highly modify your engine (like maybe forced induction), you'll need to get the crank/pulley keyed so it won't slip/spin on the crank. Stock/mildly modified engines are no problem. I installed 25% underdrive pulleys on both my Hemi's. I was able to do both without removing the radiator, but the WK was harder to do than the LX because of the limited work space. Also, the puller you use should have a pin that goes into the bolt hole of the crank and doesn't contact the threads or outer part of the crank. If you use a puller that rides on the front of the crank and bolt hole, you'll risk damaging the threads. Good luck and let us know how this project goes.
Edit: Oh, be sure to torque it to the proper specs. too. I used a good quality strap wrench to keep the crank from moving. If you're using a stock pulley, you'll probably be able to wedge a large screwdriver or breaker bar into one of the spokes of the pulley. You'll just have to see what you can rest the other end to.
