recently bought a hardtop that just needed a new glass. Bought the glass and now am looking for the hardware needed to attah struts to window. Any help would be appreciated. Thank you
Part numbers 4883496AA and 4883497AA, but I doubt you'll like the price. You may want to see if you can find them in a parts yard.
here are some after market, I think.
http://www.quadratec.com/p/omix-ada/liftgate-ball-stud-wrangler-tj-jk
Good grief! Of
course they are discontinued by MOPAR. Doesn't even say if for one or two! Probably don't even get dinner and a kiss.
Yikes, those are all super expensive. I'll have to check the parts yard near me. No way i wanna spend that for something so little. 😞@hokahay
I found a link where they had 'em in stock, but at $70 each I'd rather scour fleabay or try aftermarket.
Sounds like some deadbeat fathers out there too :surprise:One beef I have with Mopar is how many parts are discontinued. Once the vehicle is 10 years old I guess they no longer feel the need to continue supporting it.
I think it is more like they are no longer legally obligated to provide parts.One beef I have with Mopar is how many parts are discontinued. Once the vehicle is 10 years old I guess they no longer feel the need to continue supporting it.
I've had good luck with the rear glass lift struts I bought from Qtec. I bought the omix brand. Fit perfectly and have worked well for several months now.here are some after market, I think.
https://www.quadratec.com/p/omix-ada/liftgate-ball-stud-wrangler-tj-jk
I purchased a pair from https://www.gasstrutguys.com.au/ for the same reason. mine have been shot for ages now and smacking me in the head too was the last strawMy '06 Red Ruby LJ smacked me in the head yesterday 'cause the struts are gone (after only 14 years, jeez!) What replacement is everyone using? I open the tailgate about once a month, on average.
Thanks, all!
Very ingenious! I like that...Get a piece of 3/4" PVC about 11" long, remove (carefully pry off) the top of one strut from the glass end, slip the PVC over the strut & reinstall the strut to the glass. When you open the glass the PVC slides down to the bottom of the strut & drops over the end of the cylinder. That then holds the glass up. Here are some shots of when I did mine.
