Getting a P1416 with a strange set of circumstances.
If I start and drive, I get a rough idle (the misfire on #6) and the code.
If I start and drive in Tow/Haul, no rough idle misfire, no code.
If I start and drive in Tow/Haul and drive until engine is completely warmed up, I can turn off Tow/Haul and run fine with no misfire or codes.
If I stop, start and drive while engine is warm/normal operating temp, no Tow/Haul, there is no misfire, no codes.
If I forget to turn on Tow/Haul before I start driving it may or may not stop misfiring when it warms up.
If I remove battery cables and touch together (the hard reset), it will run maybe 3 times without Tow/Haul before the misfire comes back.
What I've done:
Checked the plugs multiple times.
Changed all plugs. Rechecked plugs in #6 and compared to #4 plugs. They look identical.
Replaced all four MDS solenoids. TWICE!
Run Rislone for 2000 miles before oil changes, twice, hoping to clear out gunk in MDS lifters.
What I've not done:
Swapped coils, injectors or plug boots as it runs fine in Tow/Haul and after warm up.
Is this a PCM problem?
Is there another module in play with the MDS getting/sending a bad signal?
Why would it be fine once it warms up?
2007 Grand Cherokee Limited, 5.7L
186,000 miles
K&N CAI
Over time (9 years), I've replaced radiator, water pump, power steering pump, starter, rear bearings on front propeller shaft, assorted sensors, catalytic converter (one week after purchasing- done by dealership). I may be forgetting a few things.
Any ideas, plesase?
Thanks!
Todd
What I've done:
What I've not done:
186,000 miles
K&N CAI
Any ideas, plesase?
Thanks!
Todd
